turbin
The one listed is 22mm, however I found one for the A3 Sportback(8p) part nr. H332582HA
This one is 24mm. Will it fit my LCR?
Custom exhaust.
The sport back isn't Quattro is it??
If not there is no reason it wouldn't fit as it will have the same rear end as all other VAG 2WD cars of that age
It won't fit as it's not even based on the same chassis.
Damian @ DPM Performance
you figure 22mm rear is good enough ?
When I changed the front arb to a new oem one they gave me a beefier one. Something like 2mm thicker.
