Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
to a point, but unless you are going for a large port head, it could be perceived as pointless, as spending all that cash on the uprated manifold will make very little difference on the actual road Vs a standard one
yes, it may give 10bhp more on paper, but I could not say a manifold for £500 or more could be justified for those gains though, unless going big power
remember it does not matter how bigger manifold you go, as the small port heads can only flow so much, so still you are restricted and end up with a bottle neck type effect, therefore making the larger manifold upgrade pointless
If you were going BT, then a larger manifold coupled with a large port head would make sense
Was a lovely rant tho , take it thats all the stuff you learnt from Bill then.
I'll give you a big intro....
thanks (its my new piece of knowledge, so I am proud to use it) bit like finding the right moment for the "slow clap"
I have a THS high flow exhaust manifold and it works really well. Some of the bolts were a bu**er to fit but it looks OE and it made of cast iron same as the OE.
so has any got a uprated exhaust manifold?
My car is an LC but its the same manifold. It cost me £175 from THS.
AFAIK the ATP manifold (like mine) would fit both an LC and an LCR.......
