Where these ever options on the leon and does anyone have them, i have seen some golf MK4 ones and am interested in having ago at fitting them.
its H.I.D's that are retro fitted, they are slightly different to xenons i think
heh, how odd is that I do a google search about fitting the pop up washers and a thread by you is on the first page. (Phil's my brother to those thinking 'what the hell' at the moment).
Did you get any further with these, we've fitted HIDs to our MG TF and I was thinking about some popup washers for them.
Just to clear up a bit of the HID info in this thread. Cars with aftermarket systems do, it seems, have to be fitted with washer jets and self levelling headlight systems (not suspension, although that will suffice). Although with the TF that's not much of an issue, unless you fill the boot up with something right heavy - lead weights for example!
But a washer could be fitted. If you have projector headlamps it also appears that you're on better ground legally too as they don't suffer from light scatter anywhere near as badly (if at all) as the normal style of headlight (with the lens in the glass of the headlight).
Technically they are illegal and whilst I've fitted them to a Rover 75 and MG TF, both had projector headlights.
So, the washers just pop up on their own accord then from the water pressure? I'm guessing they don't operate at the same pressure as the windscreen jets then.
Also finding some to fit the profile of the TF's front bumper is going to be interesting!
