Heated washer jets - fitting/wiring ?
muddyboots
Still hanging around
Oct 16, 2002
5,739
There seems to be quite a bit of interest on fitting heated washer jets at the moment, so thought I'd see what info is around with regards to fitting.
First off, I've found a wiring diagram which shows how the factory-fitted washer jets are wired up.
It's on page 17 of 32 here (index is in Spanish, but look for "Surtidores lavaparabrisas calefactados" :)
Z20 and Z21 are the heated jets and T2o/T2n are the connectors on them.
D/15 I think is the ignition switch (D is anyway).
Anyone know how to interpret the rest of the diagram ?
Specifically these numbers:
B135
C14
167
Also - the location of these connectors:
T2e (2 wire connector)
T6b (6 wire connector)
If I could find out where these 2 connectors are I should be able to work out where to connect the heated jet loom up.
muddyboots
Oct 16, 2002
5,739
I used to understand these diagrams from my Golf days but I can't work it out now.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
B135, C14 and 167 are internal connections in the wiring harness. B135 and C14 being lives of some description and 167 and earth.
T2e wil be the plug on the washer jet itself
And I think T6 will be a connector in the bulkhead wiring block behind the wiper motor assembley.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
If T6 is what I think it is then its a right PITA to get to. You really need to get into both sides of it to wire through it and that means half the bleeding dash needs to come out. Personally if I was doing them myself id find another way around.
muddyboots
Oct 16, 2002
5,739
OK cheers techie.
From what I remember in ETKA, the washer jets come with a loom with a connector on the end, I assuming that would be T2e. Whether the mating half of this is available, or whether another T6<->T2e cable needs adding, I'm not sure.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
66, looks like an earth point
B135 , on the mk4 golf fella there is a switched live busbar below the fuse box with relays n connections on it , this is known as 75X this could be B135 looks similar
the letters on the drawing , ro, thats rojo, red in english, so thats 12V+
BR im not sure about , tho its on the negative side of things, the numbers 1.1.5, 4 etc with these numbers seems like the gauge of wire used
A15 and C14 relays????
this is just my opinions of this , but it kinda makes sense (to me anyhow) i have etka so will have a look on that
am going to dealers to moro will ask to see there tech manuals
hope this helps
next time get it in english,
muddyboots
Oct 16, 2002
5,739
Cheers Stoney
If you could post up the page showing the heated jets, pipework & loom with all the part numbers I'd be grateful.
muddyboots
Oct 16, 2002
5,739
That's the diagram I was after. It shows the loom but not the heated jets themselves.
At the top of the picture is one wire that connects somewhere in the car, and the washer pipe that disappears off to the washer bottle somehow.
The bottom half (below the big grommet thing) is all inside the bonnet.
EDIT: The number "3"s are the connectors to the heated jets.
muddyboots
Oct 16, 2002
5,739
What we need to know is where connector "4" on the diagram connects to in the car :)
muddyboots
Oct 16, 2002
5,739
Cheers, think the wiring's going to be trickier than the piping though - can always just cut'n'join the pipe with an inline connector if need be.
EDIT: LOL yeah, seen those wiring pics before, spent ages at work one day trying to figure out where it all went !!
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
wat way does these things work anyhow, are they on a thermostat or do they need switched on , could u not rig up wiring to ur mirror defroster 4 example also do u have to change the water resovoir , wat if this is frozen
