Heater/Fan issues- ONLY HEAT???
OmegaZ27
I'm having a problem with my girlfriend's Ibiza. First, her climate control was only working on the front windscreen and in the cabin, but not on the feet. I pulled out the module that holds all the dials and everything seemed in place.
I put it back together, and now the air is only blowing on the windscreen no matter where I turn the dial, and now the heat is always on!!! :confused: I've tried many searches on the forums and the only issues that most people are having is the fan only working on 4. My fan is working completely fine on 1 to 4. So I don't think it would be the heater matrix that's the problem.
Any help would be appreciated.:confused:
disha
I had the same problem.
I saw a little plastic part was broken inside the module. The part was holding exact tension of the wire, so I had to break my fingers for half an hour to set wires back to right tension.
It's not easy, but it's also doable.
GL
OmegaZ27
It's a 1996. I'm not sure about the model. It's a 1.4L motor.
OmegaZ27
Also, would it be easier if I removed the center console? And are there any threads that have instructions on how to remove it?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
sounds like you have left the heater cable unclipped or it's broken out of it's clip
