jlocks90
jlocks90
Apr 20, 2011
28
derby
whilst driving to a show a week ago my car suddenly tried jolting me through the windscreen twice (not flooring it).. i pulled over turned it off for ten mins.. turned it back on and all was well... untill i floored it... car only boosted to 5psi!
obviously my thought was limp mode.. so again i turned car off and on again which usually does the trick but still only low boost..
got home and plugged into vagcom and these are the codes i got..
1. (17763)-035: Cylinder 1,2,3,4 ignition circuit: open: P1355 (thought coilpacks but it doesnt sound like it miss firing)
2. (16795)-035: Secondary air injection system: incorrect flow detected: P0411
3. (17964)-163: Charge pressure control: negative deviation: P1556
4. (16621)-035: Manifold pressure/ boost sensor (g31): signal too low: P0237
5. (16490)-035: Manifold/ barometric pressure sensor (g71): implausible signal: P0106
arggghhh iv had enough! is this my turbo fu**ed? any help appreciated..
Looking like a trip to available car is coming up! :cry:
will have to i suppose...just didnt want to pay out for coilpacks if it doesnt solve it... what about the boost issues? could the coilpacks be causimg this issue?
