dave_6
193
Essex
Yesterday
driving to work, 2001 ibiza
I had traction control on, but came off a roundabout hard and it kicked in and cut some power
then when slowing down coming off a sliproad the light came on, and wouldn't go off, couldnt get traction control back on, also the esp light flashed at me when I braked
got to work, all was fine after work and on way home
then in the evening, again it turned itself off and wouldnt come back on
today all was fine, then on way home from work, lost traction control, then ESP came on, then it went into limp mode and i couldnt go above 2k revs (jesus first time in limp mode and it SUCKED)
pulled over, disconnected battery for 10 minutes, and noticed fuse 3 was melted completely
couldn't remove the fuse so reconnected battery, no lights came on, and i got home ok
got home and managed to get the fuse out and cleaned up connections, took it for a good hard run, all seems fine so far, boosts fine, no lights on at all
only problem was the idle, it was too high, after a big run it idled at 1400 revs, then after I let the car cool down it still idled at 1000 revs, normally its about 800-900 I think
I did knock the pipe off the airbox thats in picture, its only taped onto the airbox and wasn't a complete airless seal either
what could be causing the high idle when warm, drove it easy for a few minutes before getting to a carpark yesterday and it sat at 1200 revs and wouldnt drop, the pipe from airbox is airtight now
so the high idle
what do we think, air leak somewhere
or is it because I reset the ecu and its still finding the right levels?
or a maf problem
Hi there.
Dreaded fuse boxes! give the contacts a good clean
Have you tried doing a throttle body reset?
When you disconnect the battery and reconnect, turn the ignition on for 1 minute and listen to the engine bay, there will be a high pitched whizzing noise, when this stops its finished its alignment. Then start it after this process and see if its cured.
Possibly you may have not let it align and thus the throttle is stuck open slighly more than usual as it thinks thats "normal position"
The Airbox pipe wouldnt make any difference, dealers always break the clips on them! its simply for the secondary air pump, it sucks air through the pipe to blow over the cat on startup (warms it quicker, and sounds like a hoover!)
Give that a go and get back to us!
cheers matey, I rang a mate who used to own one and he suggested the same thing
will give it a go, after I reconnected the battery I started it straight away so it wouldn't have had time I guess
It's fine when cold, starts at 1200 and drops to 800, but as the car warms up the revs go up at idle, when fully up to temp on way to work it was at 1250 at idle
I'm guessing it must be that as it never did it until I disconnected the battery
Yeah the 1.8T throttle bodies are a bit sensitive, generally leave them a few minutes to sort out after a battery reset.
Pull negative off battery and wait 5 minutes, then replace and do the abve.
The exact same thing happened to mine when my fan fuse went. Get it plugged in to diagnostics. With me it was just a fault code thrown up for the idle actuator. Cleared and reset the code and back to normal. Thought it was something more serious as the engine had overheated, but that's all it was.
going to try and do the throttle body thing in the morning
don't know anyone local with vag com so I guess i'll have to go to seat to have the codes cleared, bit of a pain and will no doubt cost loads
Where abouts are you mate? there might be someone local to you on here. Most people are on the look out to help each other :)
doh, throttle body didn't work
thought it had, but then when fully up to temp was idling at 1200 again
will post up seeing if anyone has vag com
I'm in colchester Essex
Well car was all fine apart from the high idle when warm
driving home tonight, sitting at 70
car jolts back, lose traction control, ESP comes on, car goes into limp mode
managed to pull over, turned engine off and went straight for that fuse, pulled it out, and it hadn't blown.
wasn't hot either and hadn't melted, connection seemed a bit thin though so I changed it over for a new one, started car, all was fine again
getting annoyed now
someone local has vag com so i'll see what fault codes I get and then go from there
Address 01: Engine
Part No: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 00000
3 Faults Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
http://wiki.ross-tech.com/index.php/17953/P1545/005445
the fuse thats melted is the abs relay, but no faults came up in regards to this,
we cleared the faults, and took it for a drive, then it was fine until i lost traction control epc light came on, and it went into limp mode
but fault it gave was 17953 - Throttle Valve Controller: Malfunction
Take off the intercooler hose, which is connected to the inlet manifold.
And see what position the throttle angle is at, if its not closed you have a mis aligned throttlebody.
You could try taking the throttlebody off the end of the inlet manifold and giving it a check over.
Did you touch any pedals when it was doing the alignment?
nope didn't touch any of the pedals and left it battery off for 10 minutes before
reconnected, left it to do the allignment
I'm running a green filter in the standard airbox, there is no cold airfeed off the airbox, guess that doesnt help
was going to clean the throttle body aswell
took it off
all looks fine, sprayed some carb cleaner in there
didn't take the throttle body off at inlet manifold as i dont have a gasket on me
hose pulled off
lack of cold air feed
general pic
cant see the ABS fuse limiting you to 2k revs.
Open the throttle with your finger from the top, all the way and let go, see if it settles back shut or open like you8rs is. or you may have another fuse in the dash gone?
high revs when the car is hot, only started after the fuse melted and i had to disconnect the battery
will try the throttle, see if it settles back down
checked fuses under steering wheel, all seemed to be intact, checked no18 the abs and that was definately still fine
at a guess, i might need to replace the fusebox on the battery afterall, was hoping i wouldnt have to
although my fault codes dont relate to that
well it does seem to be a common problem, i think a few on here have had fires from the fuseboses. And SEAT refuse to do a recall on it.
If something may have damaged the wiring loom leading to the throttle body?
