Help!!! just received second hand bumper
Charlieboy
161
Hi all.. Just received a facelift front bumper that I bought from ebay,, but when received noticed that either side of the top badge and grills behind there is thick plastic clips either side, but one side is missing, is this going to be a major problem for the alignment and fixing ? If so I wish to send back
Chino_UK
Team Creatine
Jul 19, 2009
1,587
Cheadle, Cheshire
Are they the ones that you screw through to attach? If so, it's common to hack the drivers side off if you fit a FMIC as the clip is where the pipe work goes. Mine is like that, has been for about 3 years, no problems.
Charlieboy
161
Nah there not the 1s you screw threw, it's the ones either side of the upper grills, just a little bit lower but on either side.. It separates into 2 bit 1 bit just solid plastic block and one with a thick plastic clip ?
alcazar
Click on "Post reply", then click on the image icon at the top, and post the url of your image in there.
You will need to get it hosted on the internet, I use photobucket.
Charlieboy
161
20130131_145737_zps5636d7bb.jpg.html
