went out for a blast today to do some logs etc and on the way back the temp gauge went up and the red light started beeping so immediately pulled over and left her idleing while i had a nose under the bonnet the temp started to drop and the fans kicked in full tilt
ive just noticed there is no return flow to the top of the bottle which to me points to water pump?
its just had all the belts done before i got the car, altho the garage has just marked up cambelt kit not specifically water pump, also a couple weeks ago i changed the thermostat as it wasn't getting up to temperature
would a stuck closed thermostat cause no return flow to the bottle?
just looking for abit of guidance done a good search already and read some other peoples woes, ill get onto the garage tomorrow and see if they have a record of what actually was done to the car
cheers
cheers
