ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Hey guys wondering if anyone can help me here?
Had ko3s and forge turbo intake pipe fitted recently did have same problem before but just seems worse now.
Basically when you put your foot down and hit full load in first and second around 3k rpm it makes a bang sound and then just hesitates for ages and won't rev properly. Also done it in 3rd, 4th and 5th but just not as bad.
I thought was spark or coil packs so have bought new denso ik22 spark plugs and also 4 brand new bolt down coil packs but still having same problem.
Met up with Dave today and tried his n75 and still doing same, also unplugged maf and still does same thing.
Dave had a look to see if he could figure out what was wrong but hes stumped on it too.
Heres logs i have got from 2nd and 3rd gear runs to see if anyone can spot somet there are no fault codes coming up at all though and driving around normally it's fine only under full load it has the problem.
2nd gear 002
Code:
MARKER	STAMP	 /min	%	 ms	 g/s
	0.36	1200	27.1	2.87	6.47
	0.76	1320	61.7	11.07	25.36
	1.14	1400	82	10.66	25.11
	1.54	1560	90.2	11.07	30.44
	1.94	1800	100.8	12.71	38.61
	2.34	2000	118.8	13.94	50.58
	2.74	2240	139.8	16.81	66.94
	3.14	2560	169.9	22.96	92.58
	3.54	2880	191.7	24.19	107.97
	3.94	2960	191.7	24.19	120.69
	4.34	3120	191.7	25.01	117.17
	4.74	3320	191.7	24.6	124.28
	5.14	3400	190.2	23.78	125.64
	5.54	3520	188	25.01	127.44
	5.94	3600	188	24.19	123.89
	6.34	3800	187.2	26.65	137.61
	6.74	4040	185.7	29.52	145.58
	7.16	4280	180.5	29.11	148.56
	7.54	4560	178.2	28.7	154.36
	7.94	4760	177.4	28.7	161.28
	8.36	4960	175.9	28.29	166.56
	8.76	5120	171.4	27.88	168.53
	9.16	5320	171.4	27.88	173.22
	9.56	5400	169.2	27.47	172.31
	9.96	5480	165.4	27.06	173.06
	10.36	5520	161.7	25.42	172.83
	10.76	5240	16.5	1.23	0
2nd gear 020
Code:
	TIME
MARKER	STAMP	 CF	 CF	 CF	 CF
	0	0	0	0	0
	0.4	0	0	0	0
	0.8	0	0	0	0
	1.2	0	0	0	0
	1.6	0	0	0	0
	2.09	0	0	0	0
	2.59	0	0	0	0
	2.99	0	0	0	0
	3.39	0	0	0	0
	3.81	0	0	0	0
	4.29	0	0	0	0
	4.69	0	0	0	0
	5.1	0	0	0	0
	5.5	0	0	0	0
	6	0	0	0	0
	6.4	0	0	0	0
	6.8	0	0	0	0
	7.2	0	0	0	0
2nd gear 115
Code:
	Group A:	'115
		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME
MARKER	STAMP	 /min	%	 mbar	 mbar
	0.37	1440	50.4	1000	1050
	0.77	1520	79.7	1450	1050
	1.17	1720	94	1700	1150
	1.67	2000	115.8	2050	1330
	2.07	2280	135.3	2110	1550
	2.47	2600	164.7	2180	1870
	2.87	2880	191.7	2200	2280
	3.27	3160	188	2180	2160
	3.67	3160	191.7	2180	2370
	4.07	3280	155.6	2160	2410
	4.47	3520	187.2	2150	2260
	4.87	3720	188	2160	2280
	5.27	3960	188.7	2170	2230
	5.78	4320	182	2160	2200
	6.18	4560	180.5	2150	2150
	6.58	4760	179.7	2140	2090
	6.98	4920	178.9	2130	2080
	7.38	5080	177.4	2150	2060
	7.87	5200	175.9	2120	2070
	8.27	5320	170.7	2110	2080
	8.67	5400	68.4	1000	2350
	9.08	4920	6.8	1000	1290
2nd gear 118
Code:
	Group A:	'118
		RPM	Temperature	Load	Absolute Pres.
	TIME
MARKER	STAMP	 /min	°C	%	 mbar
	0	1520	20	0	1020
	0.4	1560	20	0	1020
	0.8	1760	20	100	990
	1.2	1840	20	100	1070
	1.71	2160	18	100	1320
	2.11	2480	18	100	1630
	2.51	2840	18	91	2080
	2.91	3040	18	83.9	2460
	3.31	3160	18	82.7	2370
	3.71	3400	29	83.1	2290
	4.11	3600	26	82	2330
	4.51	3720	23	82	2290
	4.91	3960	21	81.6	2260
	5.31	4120	21	81.6	2230
	5.71	4440	21	80.8	2190
	6.11	4720	21	80.8	2120
	6.51	5000	21	80.4	2060
	6.91	4840	21	0	1530
3rd gear 002
Code:
	Group A:	'002
		RPM	Load	Inj. On Time	Mass Flow
	TIME
	0	1400	38.3	3.69	10.39
	0.4	1400	41.4	4.51	12.03
	0.8	1400	42.1	4.1	11.72
	1.2	1480	81.2	11.07	26.64
	1.6	1520	91	11.07	29.75
	2	1600	97	11.48	31.61
	2.4	1680	103.8	12.3	36.28
	2.8	1800	112.8	13.12	41.17
	3.2	1920	124.8	13.94	50.44
	3.6	2000	137.6	16.81	55.64
	4	2120	153.4	19.27	67.28
	4.4	2280	167.7	22.55	78.64
	4.89	2480	186.5	28.29	95.33
	5.31	2600	191.7	25.01	94.58
	5.79	2760	185.7	25.83	97.5
	6.19	2880	184.2	27.47	100.06
	6.7	3080	187.2	29.93	111.53
	7.1	3280	185.7	29.52	113.39
	7.5	3400	185	29.52	116.08
	7.9	3520	184.2	29.52	120.67
	8.3	3680	182	29.11	125.39
	8.7	3800	183.5	29.52	132.31
	9.1	3920	185	29.93	137.36
	9.49	4080	180.5	29.11	140.25
	9.9	4240	176.7	28.7	142.72
	10.29	4360	175.9	28.7	146.36
	10.7	4480	177.4	28.7	152.36
	11.2	4640	173.7	27.88	151.33
	11.6	4760	174.4	28.29	157.14
	12	4840	173.7	28.29	161.31
	12.4	4960	175.2	28.29	166.81
	12.91	5080	172.9	27.88	170
	13.31	5120	29.3	3.28	3.31
	13.71	4400	3.8	1.23	0
3rd gear 020
Code:
	Group A:	'020
		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME
	0	0	0	0	0
	0.4	0	0	0	0
	0.8	0	0	0	0
	1.2	0	0	0	0
	1.6	0	0	0	0
	2	0	0	0	0
	2.4	0	0	0	0
	2.8	0	0	0	0
	3.2	0	0	0	0
	3.6	0	0	0	0
	4	0	0	0	0
	4.4	0	0	0	0
	4.8	0	0	0	0
	5.2	0	0	0	0
	5.6	0	0	0	0
	6	0	0	0	0
	6.4	0	0	0	0
	6.8	0	0	0	0
	7.2	0	0	0	0
	7.6	0	0	0	0
	8	0	0	0	0
	8.51	0	0	0	0
	8.91	0	0	0	0
	9.31	0	0	0	0
	9.71	0	0	0	0
	10.11	0	0	0	0
	10.51	0	0	0	0
	10.91	0	0	0	0
	11.31	0	0	0	0
	11.71	0	0	0	0
	12.11	0	0	0	0
	12.6	0	0	0	0
	13	0	0	0	0
	13.4	0	0	0	0
	13.8	0	0	0	0
	14.2	0	0	0	0
	14.72	0	0	0	0
	15.12	0	0	0	0
3rd gear 115
Code:
	Group A:	'115
	TIME
	0.36	960	72.9	1050	1040
	0.76	1000	79.7	1320	1070
	1.16	1040	87.2	1350	1090
	1.56	1120	91.7	1370	1120
	1.96	1160	94	1390	1160
	2.36	1240	93.2	1410	1190
	2.76	1280	94.7	1440	1220
	3.16	1360	96.2	1460	1250
	3.56	1440	98.5	1480	1280
	3.96	1480	101.5	1510	1310
	4.36	1560	103.8	1540	1350
	4.74	1640	107.5	1610	1390
	5.16	1720	112.8	1690	1440
	5.54	1800	120.3	1750	1510
	5.94	1880	130.8	1910	1610
	6.34	2000	144.4	2030	1740
	6.74	2120	159.4	2060	1920
	7.14	2240	167.7	2090	2100
	7.54	2400	173.7	2140	2220
	7.94	2560	176.7	2170	2270
	8.34	2680	175.9	2180	2270
	8.74	2880	174.4	2190	2270
	9.14	2960	175.9	2190	2260
	9.54	3120	178.9	2170	2250
	9.94	3200	177.4	2160	2240
	10.34	3360	177.4	2140	2220
	10.74	3480	175.9	2130	2210
	11.14	3600	174.4	2130	2190
	11.54	3760	175.2	2140	2170
	11.94	3840	177.4	2140	2150
	12.34	3920	178.2	2140	2180
	12.76	4080	174.4	2140	2160
	13.26	4240	173.7	2130	2140
	13.66	4400	173.7	2120	2120
	14.06	4480	173.7	2120	2110
	14.45	4560	172.9	2110	2080
	14.85	4640	172.9	2110	2060
	15.25	4720	173.7	2110	2070
	15.65	4800	173.7	2100	2060
	16.05	4880	173.7	2110	2040
	16.45	4960	174.4	2100	2040
	16.85	5040	173.7	2100	2050
	17.25	4840	60.2	1000	2150
	17.66	4320	6.8	1000	1240
3rd gear 118
Code:
	Group A:	'118
	TIME
	0	1280	18	0	1100
	0.4	1320	18	0	1080
	0.8	1360	18	100	1110
	1.2	1440	17	100	1170
	1.6	1480	16	96.5	1230
	1.98	1560	15	86.3	1280
	2.38	1600	15	86.7	1340
	2.78	1680	15	89	1390
	3.18	1800	15	88.2	1450
	3.58	1880	15	93.3	1540
	3.98	1960	15	100	1650
	4.38	2080	15	94.5	1790
	4.78	2200	15	83.9	1980
	5.18	2280	15	83.5	2170
	5.58	2440	15	81.6	2290
	5.98	2600	15	80.8	2320
	6.38	2800	15	80.4	2310
	6.78	2920	15	80	2290
	7.18	3080	16	80	2270
	7.58	3200	17	79.6	2260
	8	3320	17	79.6	2250
	8.4	3440	17	79.2	2240
	8.89	3600	18	79.2	2220
	9.29	3680	18	78.8	2190
	9.69	3800	18	78.8	2180
	10.09	3920	18	78.8	2180
	10.49	4080	18	78.4	2180
	10.89	4200	19	78	2150
	11.29	4320	20	78	2130
	11.69	4400	20	78	2120
	12.09	4520	20	78	2090
	12.49	4640	21	78.4	2080
	12.89	4720	21	78.8	2060
	13.29	4760	21	78.8	2060
	13.69	4840	21	79.2	2060
	14.09	4880	21	79.6	2050
	14.49	5000	22	80	2050
	14.99	5040	23	80.8	2040
	15.39	5120	23	89.8	2040
	15.79	5120	24	89	2070
	16.19	5160	24	93.3	2070
	16.7	5200	24	81.6	2090
Cheers if any one can help
did you speak to dubsport??
maybe map related
let me know if you get to the bottom of this, its hurting my brain now, wanna know whats wrong
no spoken to prosport they said till take a look but cant get it to them till a week on saturday.
speaking to one of my mates about it last night said it could be fuel pump maybe?
still doing my head in to want to know whats wrong
would have thought it would have done it constantly if it was the fuel pump??
yea but if its only on fuell load when it tryign to get all fuel maybe just on its way out?
dont know just an idea. its doing it in all gears now though i think :(
works fine if done put foot all the way down
There's nothing jumping out at me from the logs, but it looks sluggish.
when i was in the car it was proper pulling back, hesitating, banging, farting the works .... cant see any of that on the logs :shrug:
drove fine up to 3k, then at 3k it bangs, pulls back etc etc, but it does it for about 3seconds (with foot still down) then it allows you past 3k and drives fine again
its as dave expains really doesent seem odd from logs but is really bad when driving it.
i will log 114 tonight in 3rd for you see what that brings up.
dont know what it could be.
will get 114 logs up adn hopefully some one will have an idea what it can be.
its really bad to drive though as dave found out.
Injector opening time of 30ms is running a bit rich isnt it? I bet your injectors are maxed out.
Could try playing with lemmiwinks to reduce the fuelling on increasing load.
though standard injectors are okay fro ko3s though?
how would i do that have lemmiwinks but only every adjusted the timing on there.
It basically looks like its chucking out too much fuel.
Adjust the 'fuelling on increasing load" to reduce it, try about 3-5% and see how that goes.
Are you sure your on stage 2? Dont undertand why your gettin those injector times.
will give it a try then later. whcih one you looking at for that as will change it and log again see fi makes a diffrence.
yea well should be did it at dub sport and paid for it.
Heres a 002 log on my stage 2. Maybe someone else will show theirs as well.
Code:
1960	58.6	8.2	32.47
2000	90.2	9.84	38.47
2120	110.5	11.89	48.92
2320	136.1	15.17	65.39
2640	171.4	19.68	93.53
3000	191.7	22.55	111.22
3400	191.7	23.78	146.14
3800	191.7	22.55	142
4160	191.7	22.55	153.33
4520	186.5	21.73	162.53
4840	182.7	21.32	169.28
5120	176.7	20.91	174
5360	166.9	19.68	170.25
5640	157.9	18.86	171.31
5720	156.4	18.45	174
5880	154.9	18.45	174
6000	152.6	18.04	174.92
Third column along is injector on time in ms.
o rigth i see now mines like more or less double on yours!?
and when its having the problem there on liek 29 all the time.
wonder if that could be it and whats causing it.
