Help with fault codes?
DJLC01
I need some help rectifying some fault codes that i have on my 2001 cupra 180. When driving on boost (say 4000rpm) and holding it, if i then push the throttle down my engine stutters and doesn't perform. when i then pull up it runs lumpy and on pulling away there's no power at all. with my foot to the floor it revs a little bit and all of a sudden boost kicks in and i'm away again.
i had a the codes read which are:
17608 wastegate by pass vavle - n249 mechanical malfunction (p1200)
17705 turbo/throttle valve connection pressure (p1297)
p0118 engine coolant temperature sensor 962
p0300 intermittant
p0301 cylinder 1 misfire
p0302 cylinder 2 misfire
p0303 cylinder 3 misfire
p1176 after cat limit attained
now i replaced the n249 and no real change,
seat said to change the coolant sensor and the coils packs, and possibly an air mass meter. i think its one thing tripping the rest but can anyone shed some light on it?
DJLC01
to be honest i haven't checked the codes since, i didnt because the same syptoms were still there. i did check for a vaccum leak nothing doing really.
i'll change the ect sensor and have the codes cleared and go for a run. cheers
jus a thought tho my coils were changed by the last owner bout 20,000 miles ago, i have a feeling they werent seat ones could that have a an effect?
cheers
