SeatR
399
Norway, Bergen
my exhaust cracked at the downpipe yesterday and a while after the engine light came on.
Is it because of the exhaust leak or is it another fault?
Address 01: Engine
Control Module Part Number: 06A 906 032 DE
Component and/or Version: 1.8L R4/5VT 0001
Software Coding: 11510
Work Shop Code: WSC 00000
2 Faults Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
Readiness: 0000 0000
I'd imagine the second fault code is related due to the sensor for this being in the now disconnected partially exhaust (I think).
i assume its no harm to drive with the fault codes?
P1136 - 35-00 - -
check pipes under the inlet manifold for splits.
if running rich then this is what it could be, but the same would happen if exhaust dp cracked.
