help with logs pleace:)
tarzan
cupra owner from norway
Mar 15, 2008
1,122
drammen norway
hey there this is som logs on my passat 1.8t hade a test run today but aint as fast as the cupra:D
Code:
			Group B:	'115				Group C:	'118
Engine Load	Inj. On Time	Air Mass In		Engine Speed	Engine Load	Spec. Boost	Actual Boost		Engine Speed	Air Temp In	Boost Duty	Actual Boost
15-25%	2.0-4.0 ms	2.0-4.5 g/s	TIME	740-6800 RPM	15-175%			TIME	740-6800 RPM	<=110°C	 Cycle 0-100%
%	 ms	 g/s	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar
83.5	9.18	25.17	1.34	1560	85.7	1250	1180	0.45	1400	4	0	1060
103	11.56	37.75	2.75	1920	109.8	1570	1380	1.85	1680	3	29	1240
125.6	15.3	52.83	4.06	2360	127.1	1520	1590	3.26	2080	2	60	1520
130.1	15.64	64.14	5.37	2800	129.3	1520	1530	4.46	2480	1	52.5	1580
133.8	15.64	81.56	6.67	3240	132.3	1530	1540	5.87	2960	1	47.8	1550
128.6	14.96	87.17	7.88	3640	127.8	1550	1530	7.07	3400	2	47.8	1530
131.6	15.3	97.14	9.08	4080	133.1	1550	1540	8.28	3760	2	50.2	1540
136.1	16.66	109.69	10.4	4440	139.1	1540	1530	9.48	4160	3	51	1540
143.6	18.7	132.14	11.71	4880	146.6	1510	1510	10.89	4600	4	51	1530
147.4	19.38	143.25	12.91	5200	145.9	1480	1470	12.11	4960	5	49.8	1500
143.6	18.7	150.83	14.22	5520	143.6	1440	1420	13.42	5320	6	48.6	1450
140.6	19.38	154.94	15.53	5840	140.6	1400	1400	14.63	5600	7	48.2	1410
135.3	18.7	153.31	16.94	6080	132.3	1370	1370	16.04	5920	8	47.1	1390
130.1	18.02	153.11	18.25	6320	127.1	1350	1340	17.34	6200	9	44.3	1370
124.1	17.34	151.31	19.45	6600	15	1000	1530	18.65	6400	9	42.4	1350
15	0	13.03	20.76	4440	12	1000	1140	19.87	6000	9	0	1250
and lambda an cf
Code:
'031				Group B:	'032				Group C:	'020
Lambda	Lambda	No Data	No Data		At Idle	Partial Throttle	No Data	No Data		Ignition Angle	Ignition Angle	Ignition Angle	Ignition Angle
Actual Value	Spec Value			TIME	-10.1	-10.1			TIME	Retard Cyl.1	Retard Cyl.2	Retard Cyl.3	Retard Cyl.4
				STAMP	%	%			STAMP	 CF	 CF	 CF	 CF
1.016	1	        	        	0.4	-0.6	-2.3	        	        	0.82	0	0	0	0
0.977	1	        	        	1.62	-0.6	-2.3	        	        	2.02	0	0	0	0
0.891	0.899	        	        	2.93	-0.6	-2.3	        	        	3.33	0	0	0	0
0.899	0.899	        	        	4.22	-0.6	-2.3	        	        	4.62	0	0	0	0
0.906	0.899	        	        	5.44	-0.6	-2.3	        	        	5.84	0	0	0	0
0.899	0.899	        	        	6.64	-0.6	-2.3	        	        	7.04	0	0	0	0
0.875	0.86	        	        	7.85	-0.6	-2.3	        	        	8.26	0	0	0	0
0.813	0.813	        	        	9.05	-0.6	-2.3	        	        	9.46	0	0	0	0
0.766	0.774	        	        	10.27	-0.6	-2.3	        	        	10.67	0	0	0	0
0.75	0.758	        	        	11.47	-0.6	-2.3	        	        	11.87	0	0	0	0
0.735	0.735	        	        	12.67	-0.6	-2.3	        	        	13.09	0	0	0	0
0.735	0.711	        	        	13.89	-0.6	-2.3	        	        	14.29	0	0	0	0
0.735	0.727	        	        	15.09	-0.6	-2.3	        	        	15.5	0	0	0	0
1.133	1.047	        	        	16.4	-0.6	-2.3	        	        	16.8	0	0	0	0
1.991	1.047	        	        	17.6	-0.6	-2.3	        	        	18.01	0	0	0	0
1.991	1.047	        	        	18.81	-0.6	-2.3	        	        	19.31	0	0	0	0
1.008	1	        	        	237.64	-0.6	-1.6	        	        	236.76	0	0	0	0
1.008	1	        	        	238.86	-0.6	-1.6	        	        	238.06	0	0	0	0
1.008	1	        	        	240.17	-0.6	-1.6	        	        	239.27	0	0	0	0
1.016	1	        	        	241.48	-0.6	-1.6	        	        	240.68	0	0	0	0
1.008	1	        	        	242.79	-0.6	-1.6	        	        	241.88	0	0	0	0
1.008	1	        	        	243.99	-0.6	-1.6	        	        	243.19	0	0	0	0
1.008	1	        	        	245.3	-0.6	-1.6	        	        	244.49	0	0	0	0
1.008	1	        	        	246.5	-0.6	-1.6	        	        	245.69	0	0	0	0
the car has no chip that i know but the gs is 150+:confused:
