The cheapest way to do it would be just get a remap, if thats not enough power, come and ask me
, im on my 3rd hybrid turbo
It all depends how deep your pockets are mate, if they aren't that deep, then a stage 1 remap would be best. If you want to go further, then you will need a complete exhaust system, FMIC, (otherwise you will get heat soak) PD160 intake and green panel filter, or if you'd like either a green dynatwist or a CDA cold air feed induction kit. You will also deffinately need an uprated clutch at some point, either contact JBS or pm me.
But, if your gonna be upping the power, first of all you need to prep the car, and make sure it can cope, brake, and handle. So then you will need either a seat sport AP 4 pot brake conversion or TT 312 mm brakes, uprated suspension, be it
coilovers or just uprated shocks and springs, some decent tyres, and possibly upgrade to a 17'' wheel, and use 215/40/17 tyres for a little bit more grip.
I know that this is going on and on now, but if your pockets are really deep, then a hybrid turbo is the way to go, as imho, you wont get over 200 bhp on the standard turbo. I havent had mine rolling roaded yet, but will have by the 10th JUNE, and i would estimate it to be around 210-225 bhp, belive me, its quick
If thats not ood enough for you, then maybe a bigger hybrid turbo than mine, also bigger injectors and a touch of propane injection and you should see around
280-300 bhp.
So, i hope that has helped you chap
