Thats where i've been looking at the spray bay, as i can see with the force of the air from the car being driven, i can see the water spraying across much of the area of the I/C.
Where as the spray bar should distribute it across a larger area.
Thats a bloody good guide!
Whats the reasoning behind fitting the pipe to the top of the water tank? Is it to stop it leaking out??
Without that pipe, every time you use the spray the water will continue to syphon from the bottle until its empty, this is the only way i could stop it.
Some sort of pressure releif valve may work but i was to lazy to look for one. I did try a one way valve in the direction of flow hoping that would have enough of a restriction, but i didn't.
do you think this valve might work matt if so il order it now
http://cgi.ebay.co.uk/ws/eBayISAPI....80010177300&rd=1&sspagename=STRK:MEWA:IT&rd=1
I don`t see the point in fitting a pair of jets on a FMIC since by the time you get to 30ish mph the water sprayed will only hit a very small area of the FMIC if any at all.
I see your point, but we put jets on the CRX we turbo'd and it made a big difference, it pulled harder and smoother. Not saying i will get the same results.
Do like the look of the spray bars though.
if you get a bit of clear pipe, hold it in a 'U' shape and poor water in one side the water will always level on both sides unless there is an air lock
HoocH
