How difficult to replace a camshaft position actuator?
davelyne
My garage are quoting 7 hours of labour to replace a camshaft position actuator on my 04 Leon Cupra. Does this sound reasonable?
Its annoying because they origionally quoted 1 hour of labour but now are saying it is much more difficult than they first thought. Argh!
Cheers!
davelyne
ok, so the car came out of the garage today.
I managed to pay for 4 hours of work instead of 7 since they got the origional estimate so wrong.
And guess what! after 5 minutes of driving the engine WARNING LIGHT COMES ON AGAIN!!!
This is exactly the symptom that I had when I took the car in to the garage in the first place. Only this time the car judders also even at idle.
So it looks like I have spent 700 quid in having something replaced that likely had nothing wrong with it.
Also, they told me they were replacing the camshaft actuator sensor at the cost of the part was 312 quid.
But looking at the receipt the part was 058109088k - which is a Cam Timing Chain Tensioner. Is this the same thing?
The code that the car was reporting was 16396 - BANK1 CAMSHAFT ACTUATOR.
Bloody useless place! I guess that is 700 quid down the drain?
rallynut
280
take it back mate if they first diagnosed it as that fault and its still there after they so called fixed it get them to sort it and/or refund you i wouldnt be pleased if they charged me that money for a fault that still occurs
MJ
Public transport abuser
Apr 22, 2008
5,505
13
Manchester
m.facebook.com
i'd have the sump removed, cleaned and have the oil feed pick-up replaced because i dare say its blocked allowing sufficient oil pressure to the unit causing it to function incorrectly - thus throwing up the fault.
