Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
same here not used the bracket
drilled a yellow clip at the top and screwed it into that holds well not moved yet!
Just fitted mine (double pod) and found this worked too. Line up the pillar exactly where u want it, then with a drill bit smaller than the screw (obviously !) drill a small hole through the yellow clip. Then u can screw straight into this hole. Must admit, was a bit awkward getting the screw into the hole i had just drilled.
Oh yeh i also used a longer screw (longer by about 1cm) as the one supplied would only just bite in the hole and just pulled out.
Hope that all made sense !?
Havn't fitted the gauges yet so may need some velcro aswell to help with the weight but feels pretty sturdy with just the screw.![]()
for those who have the nomad pod with halfords autogauge's, do you use the bracket to secure the gauge in the holder? I cant seem to get the bracket to fit into the pod but the gauge seems to fit snug enough without it. Just dont want the gauge falling out.
