ibizacupra said:I originally ran the Helix VR6 organic centre plate, which is pretty abrupt on take up and when you have a worn release bearing can feel a bit juddery on take up. Strangely my current 6 puk paddle Helix is smoother on progression than the organic was.. which I was'nt expecting. when converting to ABF/G60 flywheel, also allow for new flywheel mounting bolts..![]()
BenS1 said:I think I've got the same Helix VR6 organic setup that Bill had.
Personally I'm not a great fan of it. The clutch pedal is very heavy and theres loads of judder when trying to pull away slowly from a standstill (And has been since day one). Bill, you think the judder could be a clutch release bearing? Should that of been changed when the kit was fitted?
Bill, do you know what power/torque my setup is rated at? I tried to find out ages ago, and the nearest match suggested it was only rated at 250bhp! Is that right?
Ben
Ben
Glenn said:I've got the same clutch with new VAG release bearing on my VR6 - I find it a bit heavier but more positive than stock VR6 clutch but no juddering? Same comments from another Corrado VR6 owner who drove mine.
Madmile said:Dont forget vat, delivery and import duty. Reckon on $390 + 17.5% + shipping and about £25 import duty. I reckon £300 delivered all inc for the stage1 clutch.
Peloquin Lsd. http://www.peloquins.com/products_o2j.html
Exactly like mine is... rattle city..BenS1 said:So to stop the juddering I need a new release bearing? Is that a new design release bearing or just a new one of what I already have?
Are they expensive? Guess its a lot of work to get a garage to fit it?
Also, when mines cold the clutch rattles like mad. Really really rattles loads. Push the clutch down and it stops, lift off and it rattles again. The rattling stops once its warm though. Is this normal?
Ben
BenS1 said:Yeah, I've got loads I want to talk to Vince about on Sunday, but I suspect that he'll be busy.... ie. running the cars on the RR.
Ben
