Id be very suprised if a normally aspirated vts can run that sort of time! They are nowhere near as quick as that standard.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Neil82 said:Right now with your current mods going from that video my car would be side by side with you to 100 and eak a ball hair to 120 on your car, not sure what would happen after that as I've never had it over 120 and never intend to.
Mad I rekon I might get a better time using some of 3rd which runs to about 96? I'll give it a shot after work using the AP22.Madmile said:Ok then neil, lets both do a video run from 80-120mph both in 4th gear and see who is the quicker. Get your m8's vts doing a 4th gear 80-120mph run as well. And lets see who is the quicker.
You pick out the info you feel like using Neil, you pick your best run of all time, in the dry on a drag strip that is covered with old rubber which aids traction, my run was in the wet, not a multitude of runs. Just one try in the wet just for the crack. Put your money where your mouth is and provide the 80-120mph 4th gear run.
I will use 3rd as that will give me the fastest time... You use what ever gives u fastest times.Madmile said:80-120mph in 4th only. I look forward to seeing it.
CupraMatty said:why is everyone under the impression a clio 172 is quick? with or without a cup in it
the same with a VTS! 106GTis feel quicker than a VTS (just), and handle 20x better!
they are not....... unless my car is super quick!
antonyjames_uk said:106 Gti is the best handling car I have ever driven end of.
Dave McBride said:Hi Guys
Dont know why you are concerned how fast your car is up to 100mph.
I have only done about 50 miles or so in my standard Ibiza cupra. On joining the motorway in 3rd gear (40mph ish) I floored it to see the results! I was too busy watching the road to change gear as the car passed 100mph....the road cleared and I thought S#it I still have two gears to go!!! When I looked in the mirror I saw some crazy mother smiling back at me!!
. 28mpg would be like heaven
Neil82 said:not sure what would happen after that as I've never had it over 120 and never intend to.
didgy2 said:are you sure,cant believe someone would "tune" their car like you and not even give it one run to see what it would do!!![]()
i think you know exactly what would happen :birdy:
get a vid done then you can argue the point
