ibiza Electronic immobilier
JTD-ED
basicaly, i can not start my car every so often i have a youtube link but it wont let me post it on here, but i have taken it to seat had both my keys re-coded everything and still the Electronic immobiliser light on the dash board flashes on and off, on and off when i try and start it and it wont let me start it.
Some with some wisdom help me!! :(
i love the Seat Ibiza great car just its a pain and don't no what to do..... :cry:
JTD-ED
DAM IT! just been reading around for the past hour, i may have a solution taking the dash panel of and soldering something? not sure entirely.....
p30esteves
You need to buy a new dashbord, or if you go to someone that deals with ECUs, usually they can "kill" the imobilizer. But if you "kill" the imobilizer you will be able to start the car with any key from seat and you don´t need to code it.
Pedro
JTD-ED
Nice well i would love to know if anyone out there has soldered the dash board and it worked?
Nath.
The Gentlemans Express
Jan 1, 2006
8,617
16
EASTLEIGH, HAMPSHIRE
Finding poor solder joints and loading some more solder into them normally sorts out poor solder joints.
Warming up the connector pins with a soldering iron and tinning the pins (applying a very thin coating of solder to the pin) could help too. Just don't melt the plug/socket that's all.
By the way the instrument cluster comes out without removing the steering wheel. Make sure you remove it with the battery disconnected or you may get air bag faults come up.
Good Luck!
JTD-ED
is it possible to do it tiwht out removing the steering wheel? i would be most happy if i could because thats a mission.... :lol:
Nath.
Jan 1, 2006
8,617
16
As already said, yes it is possible without removing the steering wheel, just move the steering wheel all the way out and down for max room.
JTD-ED
Thank you!
no joke i have fixed it!....
i took all the dshboard out, thought F**K that when seeing that i could not get the dash board out because of the steering wheel put it all back and what do you no, it has worked all day and i have lost count on how may times i have turned my car on and off, i am only gessing it was a loss connection or something but hay! it works now fine!!! (touch wood ok?) but if anyone has any problems with the same thing just make sure everything on the back of the clocks is in thats all i can say to try and cure the problem!
Thanks everyone for the ideas etc much help!
x
