think its a tiny bit rich. only done like 5 miles with zeitronix tho! need to wait for dry day so i can log with vagcom and record the zeitronix (find it too hard driving and reading)
found out my n75 wasnt plumbed in right... doh
i had the actuator and charge pipe connections rnd wrong way!
since ive turned them round its boosting nicer but doesnt like high rpm!? its goes all spluttery and back fires!?
could this be a nackerd n75?
also running rough n idle....really scatty not smooth at all!? any ideas?
fitted wisbones!
then found out they are 30mm longer than standard wishbones! they are from a mk3 golf...look identical but 30mm longer!
look how bad my camber is!! due to the longer wishbones!!!
HoocH
MAF gives a dodgy idle doesnt it.
