Hey guys having a nightmare trying to set the ignition timing up on my ibiza (spec as in title).
Got number 1 cylinder at tdc and fitted the distributor so number one on the dizzy cap is slightly in front of the rotor arm.
Can't find where the timing mark is to set it up through with a timing light
Looked on autodata and it shows there a mark on the flywheel but i can't find one or anything what you set it to on the bell housing (or anywhere else it should be).
Theres a notch on the crankshaft pully but i haven't got the cambelt bottom cover - Is there the markings on that ???? Help required tonight if possible thank you
Paul
Paul
