Full spec list as at 11/03/16
Engine:
Rebuilt bottom end by B5 using IE Rods (non rifle drilled) and new bearings etc
Rebuilt AGU largeport head by Andrew @ ALD with Supertech inconel exhaust values
BDM baffled sump
Custom inlet manifold - BAM plenum with AMK runners
Phenolic inlet manifold spacer
PCV delete with 25mm pipes running at atmosphere
2.0 TFSI coil packs
Coil pack heatshield
Turbo/Manifold:
Relentless Pro 4 exhaust manifold
BBT K04 Hybrid (K418t - 7+7 compressor & K16 turbine) with 12PSI CR turbo actuator
Exhaust:
Full 3" Blueflame exhaust with decat
Fuel:
550cc Genesis Injectors
Walbro fuel pump in engine bay & uprated in-tank fuel pump (same as Deatschwerks DW65V)
Intercooler/WMI/induction kit:
"Wellycooler" with 76mm piping
Badger 5 V2 TIP
Ramair with custom heatshield
AEM WMI Kit – D03 nozzle just after intercooler and D01 nozzle just before TB – Solenoid and on/off switch fitted
Forge MAP sensor tube
Custom throttle body pipe
Cooling:
SFS orange coolant hoses
Direnza aluminium radiator
AFS 13 row oil cooler with aerooquip hoses
Brakes:
Standard for now but rebuilt and finished in graphite grey
Custom cold air feeds from foglights with 63mm ducting
Suspension:
KW V3's
Fully polybushed with Superpro bushes including caster increase wishbone bushes
Silver project adjustable top mounts
034 motorsport solid front subframe bushes
VW R32 front ARB
Neuspeed 25mm rear ARB
Audi S3 front strut brace
Hughes engineering rear strut brace
Gearbox:
Quaife LSD
42DD shifter bushes
Homemade short shift
Forge big alloy nob....
Exterior
Wrapped in Hexis Frozen Matte Grey
Carbon wrapped mirrors (225 version)
Cupra honeycombe front grilles
Big mouth front bumper mod
Team Heko wind deflectors
Projector HIDS with angel eyes and LED bulbs everywhere else
Interior:
Nomad dual pillar pod with Stack boost and oil temp gauges
Liquid gauge
225 Steering wheel
Recaro 2+2 seats
Headlining from 2005 model with extra sunvisor lights
LED bulbs
I think thats the lot.....
Hiya
Been a member on this forum for years, started off with an Ibiza TDi Sport, sold that and bought an Audi S3 8P thinking my days of Seat ownership were over forever.
But then i got married, sold the S3
cry
and about 3 years ago got myself a Leon Cupra R!
So 3 years and many miles later I have finally decided to start a readers ride thread...
Here is what it looks like now:
In the last 3 years its fair to say I have really used and abused my car. Its been driven up and down the motorway here and there, its done a shade under 120,000 miles (60,000 in the last 3 since i have had it).
I actually had the car converted to run on LPG. So it didn't hurt my wallet that much clocking up all those miles. But I removed the system a few months ago, as I have decided that I want my car set up for performance not economy.....
Since the start of this year I have started off a little side business and as a result have managed to acquire a large number of spare parts for my LCR
Can't say too much as the moderators might tell me off, again!!
Anyway, i put some of the choice things on my car, like teardrop mirrors and a 225 steering wheel (much better than the 210):
I have met loads of LCR owners over the last 10 months or so, and seen some really tidy cars, many of which are owned by members here.
Its been quite embarrassing for me though, since my car is in such a sorry state! Aside from driving my car far too much, I have also been using for things like taking rubbish to my local dump, transporting car parts, building equipment and lots of other stuff I shouldn't have done!
My boot was a real mess. All the plastics were scratched to death, the carpet ruined, the spare wheel space (where the LPG tank was# was full of oil and dust, not good!
So I decided enough was enough. I want my LCR to go from a piece of
into something really special.
I have a load of big plans for my car, and have done a lot of research and have a good idea of what I want to do with my car.
By the time it is finished, practically every part of the car will be improved or renewed.
Plans are:
1. Rebuild engine
Well I thought I would start off with the most important #and expensive!# part first. I still want to be able to use my car as I need it for work. So I picked up an AGU engine off the bay very cheap:
The AGU is probably the most sensible engine to rebuild out of all the 1.8T's. It has a forged crank and 20mm wrist pins #Like the LCR), and as an added bonus, a largeport head.
So I have been been busy spending money gathering parts for my rebuild.
Engine:
BDM baffled sump
2.0 TFSI coil packs
Turbo/Manifold:
Exhaust:
Fuel:
Badger 5 V2 TIP
Cooling:
Brakes:
Suspension:
KW V3's
VW R32 front ARB
Gearbox:
Quaife LSD
42DD shifter bushes
Exterior
Interior:
Liquid gauge
225 Steering wheel
Recaro 2+2 seats
LED bulbs
Hiya
Plans are:
1. Rebuild engine
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
