The bolt that fell out was the bottom one near the wastegate actuator. There was no space for a nordlock washer in there. I've fitted a better bolt, and I'll keep an eye on it. The other one that came very loose doesn't have this type of washer either.
The rest could be tweeked, but had not loosened enough to produce a leak. TBH I don't think I tightened those ones as much as I could have, as I used a different tool this time.
If the bolt falls out again, I'll remove the downpipe and have it welded like a captive nut. Will order another nordlock for the remaining bolt.
