I was wondering if anyone knew if it is possible to change the pink / red dashboard colour on the dials - thinking I would prefer a different colour, just not too sure whether it was possible and what work it would entail!
I have the dimmer set as low as possible, but would like to turn it down some more (make darker) as I don't like bright lights or feel I am in blackpool when driving at night.
Can it be turned down more (make darker)?
If yes, How can I do this?
lol i was goin be cocky and say, turn your lights off.. but that wont work lol..
the only way i could think is to get a different dimmer switch.. one that will dim lower.. or get some sort of tinted cover over the dash?!! not a clue other than that..
i do have them dimmed right down, well as far as the dial will let me anyay. I want to go some more, as dislike bright lights. Even wear sunnies in winter due to bright light hating.
think i understood what you were saying fl@pper but not sure.
Could you put in pigeon english for me please? as i'm really rather thick at car mod and electrics.
You can get an adjustable resistor that will go in line with the dimmer and clocks,so for example the standard dimmer is turned down and say its 20%, with this adjustable resistor you could go to 1%.
yep, that works for me.
only need to be able to see speedo & revs at night. all others are informational that can become lit ala SAAB when you need to be informed of something.
the aircon/heating area lighting could replace blackpool on its own
