Hi all,
Just a quick one to let you know of another happy customer of Diannes-shop on Ebay
Took me 2 hours to install (taking my time & figuring it all out lol) - but all are working and looking VERY nice.
Mounted the drivers side ballast on the existing screw by the light (upside down) - but may swap this to behind the water reservoir (just need to take it out - 2 bolts by the look of it) in the near future.
Tried mounting the passenger side ballast onto the existing bold that holds the air feed into place, but couldn't get it on (then I dropped the nut washer thingy, it's under the battery somewhere...........). Ended up removing the harness from the ballast & sticking it to the side wall by the battery (using "scarey tape" - type of double sided tape), thats not going anywhere.
Took me a while to gt my fat fingers in between the battery & light cover to get everything in, but got there in the end....
Few q's though....
What side light bulbs give the best match ? I've put in some Phillips blue vision & they look crap compared to the HID - too much yellow
The casing around the HID bulb - when you screw the top bit off, how did you get the bottom casing off, or did you leave it on ? I cracked it off with pliers.........
Will get some pics up tomorrow
Few q's though....
