Had to take mine out, Every time you indicated it cut the DAB signal out, and they weren't the cheap bulbs.
Normal bulbs ok, led no DAB when indicating![]()
I did this last night. So pleased with the new ones. Much brighter and now matches the front ones.
Thanks for the guide. I can confirm that it is extremely easy to do.
Stick a 1/2" drive extension in it.My 2016 light "nut" is square with a flat scree head inside it and the washer all part of it! Has anybody seen the likes of this before? Everything else seems to be the same, but no way to use a hex nut on it.
Incidentally my boot light is a full LED unit as standard as well! Although glove box isn't.
Does anybody know if these would fit and/or be decent?
http://www.xenonbulbs.co.uk/CANBUS-LEDS-Bayonet-BAU15S-5W-AMBER?search=BAU15
I assume given your most recent post you've already bought them, but personally I'd say no, as I'd want ones with some LEDs on the sides to make maximum use of the reflector and provide the most brightness. See how you get on with them though.
I actually haven't got them yet. I was wanting to make sure I was comfortable accessing the panel before ordering them.
Thanks for the advice, I absolutely see what you mean and I think I'll hold off and spend a few more quid on them instead.
In that case, here's the ones I have:
http://www.ebay.co.uk/itm/2x-581-PY...rn-Signal-Indicator-Light-Amber-/221862101538
Had them in since September and have been very happy with them.![]()
1. I note the listing does not mention as to whether they are canbus error free, have you noticed any problems ?
2. Do they affect the DAB signal at all ?
