keepthefaith
Hi
Wondering if any of you guys have come across this before..
I've got an 130PD TDI Sport on a 52 plate
About 16 Months ago maybe more my Tacho suddenly started to intermittently fail, it basically works but it offsets itself and continues to work but with a huge offset. Idle is saying just over 5000RPM. Had it checked out with a local specialist on the VAG COM and it reported back that there wasn't a problem, well there clearly! I rang my local dealer and they hadn't heard of the problem and said that you may need a new instrument cluster at a cost of around £500. So of course I then thought I can live without it at that price...
But now my Temp gauge has gone. Not intermittent this time just no signal at all when all the other gauges are reading normal bar the tacho.
First of all has anyone experienced these problems? or anyone have any fixes?tips?
I need to check the ground wiring to the instument cluster. is it easyily accessable?
Has anyone removed the dash? or bought a new one due to this type of problem?
Any help would be much appreciated.
