W88DSY
Hi,
I am currently running a 20vt cupra with K&N, forge DV, Milltek exhaust with an Ultramap remap. was thinking of adding a forge intercooler but don't know much about how much it improves performance and if in order to fit one i would need to make any other modifications. Any ideas??:shrug:
i dont believe you need any other mods to fit an fmic (which i assume is the type of inercooler you are talking about). i dont imagine you will see massive performance gains however, given you're current setup i would have thought you wouldnt be far off a stage 2 remap ;)
if i go down that route am i right in assuming that involves changing thr FPR, cat and thats it?
i believe so, do a search. i was reading a very long post only an hour or two ago by someone who had gone revo stage 2 and went into ALOT of detail about it!
i believe the fpr is only about 40 quid!
Push, do you think that thats why i might be experiencing a slight flat spot between 3500-4000rpm, because i need to change the FPR.
sorry i cant remember, i know the post was from about 18 months ago.
i'd love to go all out with fmic, race cat, etc. but i just dont have the money at the moment (got a loan to buy the lcr) and the missus and myself are thinking of moving to new zealand in a year or so. :(
fitting a Forge FMIC is worth every penny
its not about having massive BHP increases, but what the Forge FMIC does is greatly reduce the intake temperatures, therefore allowing for boost to be held alot longer and the peak figures to be alot higher. Basically heat soak is greatly minimised to the turbo, allowing power to be held almost to the redline, as with the standard IC, it simply cant cope with the power and creates too much heat
since you already have quite a few mods, a Forge FMIC would compliment them nicely
my recommendation - go any get one! :D
it depends what you need. by the sounds of it you need downpipe and cat (£400?) and fpr (£40?) + the remap (£no idea but i know revo stage 2 is usually much cheaper than stage 1)
I could be wrong but i'm sure there's not to many downpipes available that fit on to the miltek, it won't be cheap anyway.
Think revo stage 2 is an extra £50 or so
Hmm cheers for that.
Harvey did you fit one youself?? if so is it easy?
harvey did you remove the smic's? i assume you have to?
sorry, are you talking about an LCR?
mine is just an LC, so only one smic to remove
the LCR smic's are both removed for one single FMIC, but still the same theory and work applies for fitment
Nice one, cheers for that!
How much are they charging you?
erm well i was part of the Forge GB, so I think its £125, which is very reasonable
most importantly, its peace of mind as I know it will get fitted properly as the CS from Forge is A1
