Deleted member 12147
Is it possible to fit two dump valves to a cupra engine? The reason i ask is because on my punto turbo it was possible to put one dump valve pre intercooler and one post intercooler. What i was thinking of doing was keeping my forge 007p in the standard position and fitting a second atmos dump valve either pre or post intercooler. Just wondered if anyone has thought about it or tried it before? I've done a search and can't find anything.
seems pointless? in theory ud lose power?
theres barely any pressure to recirculate anyway, 2 dvs would cause havoc, especially as the original dv is pre intercooler (except with a relocation kit) and u want as much pressure as possible after the intercooler?
I agree with mOrk and the others, i have never been a fan of putting Atmospheric DV's on the VAG engines, Jap motors and probably the punot's i imagine are fine with it but having the air re-circulated back over the MAF means that an atmospheric one is not allowing the recirc to happen.
I was just wondering if it was possible, i miss the sound of my old DV no matter how chav it is. Oh well was just a thought, will have to put my punto back on the road again mi thinks.
has any one tried those part recirc and part atmosph DV's? Rob Don was gonna buy one ages ago if i remember. they any good?
you could stick one up your a...... no i won't go there! :p (would make a nice whoosh morning after a curry :p
no point fitting a second one it would just mess something up. it you use a open induction kit it increases the dump noise :)
i once fitted a half recirc half atmos valve, but it idled like **** at the lights and had some serious turbo lag. i ended up turning it to fully recirc before selling it on. they dont work.
my car cant drive without a recirc valve normally so i have the forge dv..
but if you put a forge bov (like 004 ) next to the trhottle body it certainly works
but you must find a good spring to fit becouse you must adjust it that the bov only opens at full boost
no probs at all and no signs of a rich running car
i was just curious if this would work and jes it does
