chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
going to pain the calipers on the motor tomorrow, got myself a trolley jack last weekend to do it but i want to get the car on blocks rather than just on the jack itself. where is the best place on the car to do this, on the same part of the chassis as the jack goes or somewhere else?
edit - also noticed the rails seem to have got a bit chewed up when i used the jack on sunday, is that normal as i don't want to cause problems if i have to use the jack in the boot for any reason
Mate im also planning to get my calipers painted in the near future too, cant wait! :shrug: Just soon as i get my mate to help me do it :D ...
Do the calipers have to be removed to paint them? I heard its not easy to take them out?
Sorry i have no idea about the jack, im sure someone can help with this :think:
the kit i have seems to indicate that you don't need to remove them, just to tape up the brake lines and ensure you just are careful with the paint
I usually stick my trolley jack under the subframe mountings. not had any problems yet :)
Excellent :D Where did you get your paint kit from mate? If it was Ebay which brand?
A friend of mine did his the other day and the paint seems to be self smoothing. Just apply plenty of coats and take care with the brush, it should look mint. A small brush was supplied with his kit, pretty much fool proof. No need to remove the calipers to do this.
If the subframe are those squarish beams, then I would not advise it, mine crushed in when I used them with my trolley jack. I now put it on the bolt at the end of the wishbone arm.
Slightly OT, but just ordered a 2 tonne trolley jack and a pair of 2 tonne axle stands from Wickes online - not sure about the quality but can't argue with the price - £17 delivered!
Will see what they're like when they arrive :)
I did mine last Summer & will again soon, its easy to do with them left in place, just as long as you dont have 12 Stellas the night before :cry:
Top tip, dont put the paint in a plastic container to work out of.....it'll melt the plastic & you'll have paint all over the floor :censored: but done mine red & they look [B)] and they dry in about an hour
got one half done, gotta spin the car round in a few mins to do the other side due to parents cars and narrowish drive i need to keep out the way
am giving it an hour and a half before putting each wheel on and it seems to be enough
