James, could you point me in the direction of the ecu reset all i keep finding is the disconnect the battery one, but want to do the vag-com reset, i will change to the super unleaded fuel there's no shell garages around here but have a tesco's their equivalent is good so will use that, should i wait until i have used this tank of fuel then refill with the tesco super unleaded and then ecu reset?
yeah, use the pants fuel, fill up with thesco 99ron(rocket fuel)... then ecu reset, drive the car hard then the ecu will learn this style, itll take a couple of tanks to feel the most benefit.
not sure how to vagcom reset, do you have vagcom?
just reset via battery, its the same and as effective
