Those logs look ok. There is no reason that your requested should have changed. Do you have any old logs of requested and actual rom before you had the ko3s fitted? There will be hardly any difference between a k03 and k03s map. Looks like your current one just doesnt request much and probably never has.
Will have my New jabbasport Ecu here 2morro...Its mapped for a k03s which was martin M old Ecu...
It made 227bhp without a big manifold and 3'' downpipe and de-cat which mine has...
The map i had before was very mild map as it didnt have that aggressive kick to it..
On my k03 my gauge would hit 20psi then instantly hit 10-11psi at about 3.5rpms..it was nippy but never had that kick to it..
So hopefully this new map will sort the problem,,,And once its on What Logs Should i do and what logs should i do together..
Edit:
Just found a old log and Dpj worked it out and it spike to 19 then to 10psi....so yeah my map wasnt requesting much...But went well on my k03 turbo tho..
Right UPDATE...
Fitted the 4bar and jabba map 2night and it goes like ****!!! but when i boot it in 1st it hits 10psi But it really quick...So am Guessing ive got a boost leak somewere as am Loosing 10psi lol As this map is Martin M old Ecu which hit 21psi and Held at 14-15psi....
I have a ATP with a 50mm 90degree bend goin on to the Turbo..But the k03s Housing is 45mm but its on really tight but i cant see obvisously if theres any gaps...
If that was Loose and Sucking in Un-meter air would that make me Loost 10psi..?
Am running out of ideas?
I'm not sure but i'd say if it was running lean then the ecu will pull everything back to protect the engine i would have thought. So less boost.
Lol it wouldnt Let me do logs as it kept goin in to limp mode...
Curzons gonna post up in a min...But my map is requesting high boost but it just cant meet it....It weird...
It gives boost untill it starts to hold it then i get this code..Which we cleared and keeps coming back...
17964/P1556 - Charge Pressure Control: Negative Deviation
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too Low
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
The logs are virtually useless as it kept going into limp mode, so it doesn't show anything.
When we tried doing the logs if Danny tried to build up the boost in 3rd or 4th from 2,00rpm it went straight into limp mode, with the code Danny's posted up.
Although if he put his foot down through 1st, 2nd, 3rd and 4th it didn't go in limp mode
Do you have a 118?
I bet you got a massive boost leak which causes negative deviation.
Or it could be there isnr enough pre load on the actuator to build boost to match the requested low down the rev range. Like at WOT at 2k your map might be asking for 1.2bar and your turbo needs to spool to get to that, the longer it takes to hit requested the more of a chance it is that you'll hit limp mode.
These are the logs i have though, but there pretty much useless but have a look
Code:
	Group A:	'115				Group B:	'118
		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar
	0.75	2160	20.3	1010	1190	0.35	2600	18	0	1770
	1.55	2080	83.5	1010	1320	1.15	2000	17	93.7	1090
	2.35	2160	42.9	1010	1080	1.95	2120	18	0	1210
	3.15	2000	12.8	1010	1100	2.75	2200	18	0	1130
	3.97	2800	30.8	1010	1040	3.55	2120	18	0	1050
	4.86	2760	9.8	1010	1050	4.46	2760	20	0	1070
	5.66	2800	33.1	1010	1010	5.26	2760	21	0	1040
	6.46	2880	96.2	1920	1170	6.06	2800	21	0	1070
	7.26	3160	142.9	2310	1890	6.86	3000	21	76.1	1600
	8.06	3480	148.1	2290	1940	7.66	3320	20	79.6	1930
	8.86	3800	145.1	2320	1900	8.46	3640	18	80	1910
	9.66	4120	145.9	2320	1910	9.26	3960	18	80.4	1910
	10.46	4400	137.6	2270	1920	10.06	4240	19	82.4	1930
	11.26	4640	103	2220	1330	10.86	4520	18	19.2	1370
	12.06	4800	103	2120	1310	11.66	4720	18	15.3	1320
	12.86	5000	103.8	2040	1290	12.46	4920	19	11.8	1300
	13.66	5200	103	2020	1290	13.26	5080	19	10.2	1290
	14.46	5360	102.3	2010	1290	14.06	5280	19	10.2	1280
	15.36	5520	100.8	2000	1280	14.86	5440	19	10.2	1280
	16.27	5560	103	1010	1280	15.87	5640	19	10.2	1270
	17.16	4440	6	1010	1090	16.67	5040	18	0	1210
	18.04	4280	9	1010	1060	17.56	4320	20	0	1070
	18.86	4080	9	1010	1050	18.46	4200	21	0	1050
	19.64	3920	9	1010	1050	19.26	4000	22	0	1050
Code:
	TIME					TIME
	0.01	2120	27.1	1010	1200	0.49	2080	18	0	1080
	0.89	2120	36.8	1010	1040	1.29	2160	20	92.5	1100
	1.69	2280	98.5	1930	1310	2.09	2360	21	89.4	1550
	2.48	2520	136.8	2060	1810	2.88	2640	21	80	2000
	3.28	2800	145.9	2260	2060	3.68	2960	20	79.6	2020
	4.08	3120	144.4	2290	1970	4.49	3280	20	79.6	1960
	4.89	3400	149.6	2280	1950	5.28	3560	20	80	1950
	5.68	3720	142.9	2290	1920	6.09	3880	21	28.2	1910
	6.48	3960	101.5	2310	1380	6.89	4040	20	27.8	1380
	7.29	4160	102.3	2300	1370	7.79	4280	20	23.5	1360
	8.3	4320	78.9	1010	1540	8.7	3840	19	0	1180
	9.1	3440	72.2	1750	1010	9.6	3480	21	28.2	1420
	9.98	3560	101.5	2310	1380	10.38	3600	20	16.1	1380
	10.78	3560	16.5	1010	1260	11.18	3560	18	0	1110
Code:
	Group A:	'002
		RPM	Load	Inj. On Time	Mass Flow
	TIME
MARKER	STAMP	 /min	%	 ms	 g/s
	0.02	2480	9.8	0	4.94
	0.38	2480	17.3	2.87	12.47
	0.78	2520	60.2	12.3	40.19
	1.18	2560	94	13.53	53.94
	1.58	2640	121.8	16.4	72.22
	1.96	2800	142.9	18.45	81.03
	2.38	2960	147.4	19.27	84.58
	2.76	3120	148.1	19.27	88.19
	3.16	3240	149.6	19.68	93.81
	3.56	3400	152.6	20.09	99.42
	3.96	3560	148.1	19.27	98.5
	4.38	3720	147.4	18.86	105.53
	4.78	3880	133.1	17.22	79.47
	5.16	3960	103	12.71	76.08
	5.58	4080	103	13.12	80.44
	6.08	4160	103	13.12	82.08
	6.48	4280	103	13.12	85.44
	6.99	4400	103	13.12	86.97
	7.39	4480	103	13.12	88.17
	7.79	4560	103	13.12	90.61
	8.19	4640	103.8	13.12	90.47
	8.57	4760	103	13.12	92.47
	8.97	4840	103	13.12	94.36
	9.37	4920	103	13.12	97.28
	9.77	4720	20.3	1.64	0
	10.17	4200	7.5	1.23	4.19
Do you think the actuator has been wound in, so the map is asking for more boost than the actuator is allowing so its cutting it out into limp mode?
Did before he changed the map, made no difference
That means nothing. Old map was requesting a smaller amount of boost. Push things further as you have done with a map requesting more boost and its more likely to show weakness or fail. Try swapping it again.
I have said before you have a leak somewhere but you seem sure nothing is leaking. I would be going over everything again.
Count your actuator threads but from what I remember somebody wound theres right shut on a k03 based turbo and didnt get limp mode although it would depend on the parameters of the map and the spring in it.
