Maybe your old k03s was fubared.
Like chris said it did pull 231bhp on the last RR i went on and always pulled good airflow figures.
It was only furbed when a washer decided to pay a visit to the turbine :doh:
Chirs you back in benson yet? ill pop up and give you a decent look at it and take you for a spin if you like?
Just checked the threads, and 13-14 is showing so i wouldnt say its been played about with much considering my old k03s was showing a few more than that and only peaked 22-23psi.
So looks like the mani might have made a good bit of differance :)
To be honest id like to think that mine was a 1 off but i doubt it.
From the picture ive seen thats on the kinetic website that one looks like it should fit without any problems as the top of the flange looks flat where as mine had raised humps near above the bolt holes which made it fowl the head.
Its quite hard to explain and unfortunatly i didnt take many pics as i just wanted to get it on.
It wasnt a major problem grinding it down although i shouldnt of had to do it at all. Touch wood every things ok so far.
Im taking her back to the last RR that i used so i should get a pretty accurate idea of what the mani has actully added. :)
It might be worth contacting him on the msn addy that i sent you to see if he could send you a decent picture of the manis they are sending out at the moment because im sure mine was differant to the ones pictured on the site.
If he sends a pic over post it up and i should be able to tell if it should fit or not with out modification.
I have just order one for me (with a k04-01 to replace my turbo), i will post if i have any fitting issues...
