watto83
had it replaced at seat today because of engine management light coming on, but got it home and now the light has come back on after been removed? aaarrgghh!!! what does everybody think it could be? 3 faults came up which were 1.lamba probe failure and the other 2 were fuel mixture related. i got an x 2001 leon cupra turbo? anyone got any ideas?
MAF sensor possibly? Any other symptoms? Rough idle for example. I'd say MAF, but also give the throttle body a clean too.
Anyone else have any ideas?
Shell V-Power all the way :)
Cars not louder? When the Lambada goes, generally its a good idea for the cat converter to be changed as they work together.
when the turbo comes in it seems to loose a bit of pressure and hiss quite alot and im also gettin quite abit of turbo whistle? could i have a dodgy dump valve?
sounds similar to what my vrs was doing a couple of weeks back.
turned out that the rubo was loose.3 reatining bolts were so loose i could turn them by hand.car ran"ok" but there was loss of boost and it sounded awful
car aint making no wierd noises really maybe dodgy dump valve or actuator
