tonipieleanu
I'm using Vag-Com 3.11 and in group 031 I'm getting a reading in Volts and not the actual AFR (lambda).
Does this mean my lambda probe is narrowband? I haven't seen the voltage on this channel fluctuate other than 0-1V. Is the reading wrong or has something to do with the lambda probe itself and the ECU.
I have some lambda probe issues even after changing it (with a NTK/NGK one, which should be equivalent to a OEM probe).
Should be a wide band lambda, if you multipy the voltage by 14.7, this will give you AFR. ie 0.75 Volts = 11.025AFR
Ivan
0-1v = narrow band
if it was wide band you would have seen values larger than "1" (especially when you let off throttle after acceleration)
