LCR charge pipe
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
Karlos have you got any pics of your engine bay in its current state please? :)
here you go mate, some pictures taken today just for you.......
DamoR
Smoked!!!!
Oct 9, 2006
726
Birmingham
www.myspace.com
Looks lovely mate exactly how I want mine. Do you think the TIP helps make the MAF more stable compared to the standard hose? I think blue goes best on a grey car :)
What strutbrace it that?
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
the maf doesn't move about much at all now so the bracket for the induction kit has less work to so is probably less likely to break the maf housing. the strutbrace on mine seems to have made a difference when cornering, and doesn't seem to wander about as much going quickly in a straight line either!
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
I thought my ears were burning.
Chopping the silicener out isn't that easy, but there is a knack. Do a search on "charge Pipe" for lots of info, plus some pics here http://homepage.ntlworld.com/p.revill/Charge Pipe/
Basically, you peel back the edge (you can see a "join") then slip a small chisel in and chop downwards, chopping the fins off the back. It helps to burn some of it out first to make it more brittle. Once it's all out, you can weld in a replacement bit of tube. You might be able to sleeve the inside of the silencer without removing it, but I think that would be a bit pointless...
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
i don't suppose you have any left do you phil? we did discuss it a while back but you didn't get back to me! ;)
