Thats bad news :( I hope thats were it ends for you :)
You gonna take the opportunity to do any headwork?
Wish you the best of luck, I feel your pain believe me, lol
Iv not got a clue about engines mate I got told that.
Cylinder 1 has oil in it that's why i have the misfire.
I got told I would need it all stripped out and get new pistons rings and valves. So I thought if im doing that I would get new rods as well.
If any can help me out on this it would be a great help.
Little bit more info as to whats happening
Car missfires at full throttle from 5k+, normally pop the codes random multiple misffires detected and missfire on cylinder 2, occasionally also get a missfire on cylinder 4.
I have also noticed if I accelerate on part thottle the car suddenly loses torque (when I'm driving I can feel a jolt and I continue to accelerate but not with the same torque as before) almost feels like the DV dumps or thottle closes slightly. I've serviced the DV in case something was sticking. I'm not running mega boost at the moment either, normally around 1 bar maybe slightly more.
I logged blocks 15 and 16 to show miss fires and sure enough it picks up the missfires mainly on cylinders 2 and 4 (get a rare one on 1 and 3 but 2 is always the highest followed by 4)
Oddly though when I experience the problem with part throttle there's nothing at all showing on the missfire counters.
I also logged the knock sensors and highest CF's I'm getting is 5.3 and these are fairly rare.
I was going to log block 031 next and the one for the throttle body (block 60?)
Any other suggestions?
Managed to do a tiny bit of logging today, not much as it was only on the way to the shops.
The problem I mentioned in earlier posts regarding the dip in torque is a lot more apparent when driving the car from cold so much so that it builds up boost then dumps builds up boost dumps again etc, all this happens very quickly so its dumping around 2 - 3 times a second.
Could someone look at the logs below and give their views? Fuelling seems seems to be lean in parts and then really rich in others. I've tried to put markers when the problem happens but its probably a few seconds before the marker.
Code:
	Group A:	'031				Group B:	'115				Group C:	 Not Running
		Lambda Control	Lambda Control	Bin. Bits	Bin. Bits		Engine Speed	Engine Load	Boost Pressure	Boost Pressure
	TIME	Bank 1 (actual)	Bank 1 (specified)			TIME	(G28)		(specified)	(actual)	TIME
Marker	STAMP					STAMP	 /min	 %	 mbar	 mbar	STAMP
	63.88	0.977	0.984	        	        	64.17	1080	39.1	1040	1000
	64.48	0.899	0.984	        	        	64.78	1840	69.2	1010	1010
	65.08	0.938	0.984	        	        	65.38	1600	75.2	1090	1060
	65.68	1.008	0.984	        	        	65.99	1360	82.7	1220	1070
	66.28	0.992	0.984	        	        	66.58	1840	86.5	1200	1120
	66.89	0.899	0.984	        	        	67.21	2440	96.2	1410	1260
	67.5	0.899	0.984	        	        	67.8	3120	106	1360	1550
	68.1	1.016	0.984	        	        	68.4	2880	14.3	1000	1310
	68.7	0.961	0.984	        	        	69	2120	75.2	1450	1080
	69.31	0.953	0.984	        	        	69.7	2400	109	2030	1320
	70.01	0.899	0.984	        	        	70.42	2840	153.4	1960	1820
	70.72	0.961	0.984	        	        	71.01	3200	191	2160	2150
	71.32	1.016	0.984	        	        	71.62	3440	191.7	2020	2380
	71.92	0.883	0.984	        	        	72.23	3480	181.2	1470	2100
	72.52	0.75	0.984	        	        	72.82	3840	166.9	1460	2070
	73.14	1	0.984	        	        	73.44	3200	13.5	1000	1250
	73.74	0.75	0.984	        	        	74.03	2480	39.1	1000	1050
1	74.34	0.992	0.984	        	        	74.64	2520	58.6	1000	1090
	74.93	0.961	0.984	        	        	75.23	2560	59.4	1000	1150
	75.55	1	0.984	        	        	75.85	2560	58.6	1000	1160
	76.15	0.992	0.984	        	        	76.44	2600	59.4	1000	1170
	76.74	0.977	0.984	        	        	77.05	2600	47.4	1000	1150
	77.36	0.969	0.984	        	        	77.66	2600	36.1	1000	1070
	77.96	0.977	0.984	        	        	78.25	2560	34.6	1000	1040
	78.56	0.969	0.984	        	        	78.87	2560	34.6	1000	1030
	79.16	0.984	0.984	        	        	79.47	2520	33.8	1000	1020
	79.87	1	0.984	        	        	80.18	2480	36.1	1000	1020
	80.48	0.984	0.984	        	        	80.78	2440	37.6	1000	1020
	81.08	0.977	0.984	        	        	81.38	2440	37.6	1000	1020
	81.68	0.977	0.984	        	        	81.98	2400	37.6	1000	1020
	82.28	0.969	0.984	        	        	82.59	2400	37.6	1000	1020
	82.89	0.969	0.984	        	        	83.2	2360	34.6	1000	1020
	83.49	0.977	0.984	        	        	83.78	2360	33.1	1000	1020
Code:
	139.51	0.977	1	        	        	139.81	840	28.6	1000	1000
	140.11	0.961	1	        	        	140.42	1600	66.9	1000	1000
	140.71	0.969	1	        	        	141.02	1760	68.4	1000	1050
	141.33	1	1	        	        	141.62	1560	73.7	1050	1090
	141.92	0.992	1	        	        	142.23	1720	74.4	1400	1110
	142.52	0.984	1	        	        	142.84	2400	103	1630	1260
	143.14	0.891	1	        	        	143.43	3200	113.5	1380	1750
	143.74	0.914	1	        	        	144.04	2920	13.5	1000	1270
	144.35	0.883	1	        	        	144.64	2320	90.2	1600	1120
	144.94	0.961	1	        	        	145.25	2520	118	2130	1410
	145.54	0.914	1	        	        	145.84	2880	160.2	2280	1890
	146.17	0.969	1	        	        	146.47	3240	191.7	2390	2190
	146.76	0.992	1	        	        	147.06	3560	190.2	2330	2270
	147.36	1.016	1	        	        	147.65	3960	191.7	2090	2340
	147.96	1	1	        	        	148.26	4160	191.7	1550	2290
	148.57	0.906	1	        	        	148.87	4200	139.1	1000	2170
2	149.17	0.86	1	        	        	149.48	3240	15	1000	1180
	149.78	0.774	0.969	        	        	150.08	2760	58.6	1000	1060
	150.38	0.867	0.938	        	        	150.68	2840	59.4	1000	1280
	150.98	0.891	1	        	        	151.27	2840	39.8	1000	1110
	151.6	0.977	1	        	        	151.88	2840	39.8	1000	1070
	152.19	1	1	        	        	152.48	2840	39.8	1000	1060
	152.79	0.992	1	        	        	153.09	2800	37.6	1000	1050
	153.4	0.992	1	        	        	153.7	2760	38.3	1000	1050
	154	1	1	        	        	154.3	2760	39.8	1000	1050
	154.6	1	1	        	        	154.91	2720	35.3	1000	1050
	155.21	0.984	1	        	        	155.51	2720	31.6	1000	1040
	155.81	0.984	1	        	        	156.11	2680	23.3	1000	1030
	156.41	1.047	1	        	        	156.71	2600	18	1000	1010
	157.02	1	1	        	        	157.31	2560	17.3	1000	1010
	157.62	0.984	1	        	        	157.92	2480	15	1000	1000
	158.23	1	1	        	        	158.53	2440	29.3	1000	1000
	158.83	1.016	1	        	        	159.13	2360	30.8	1000	1010
	159.43	0.977	1	        	        	159.73	2360	30.8	1000	1010
	160.03	0.977	1	        	        	160.34	2320	24.1	1000	1010
	160.65	0.984	1	        	        	160.93	2280	23.3	1000	1010
Code:
	360.81	0.93	0.953	        	        	361.09	1920	42.1	1000	1050
	361.4	0.953	0.945	        	        	361.69	2000	38.3	1000	1040
	362	0.961	0.945	        	        	362.31	2040	30.8	1000	1030
	362.61	0.93	0.945	        	        	362.9	2000	18.8	1000	1020
	363.2	0.992	0.945	        	        	363.51	2000	15.8	1000	1010
	363.81	0.969	0.945	        	        	364.11	1920	15.8	1000	1000
	364.42	0.961	0.945	        	        	364.72	1880	18.8	1000	1000
	365.01	0.945	0.945	        	        	365.32	1840	19.5	1000	1000
	365.62	0.945	0.945	        	        	365.93	1800	28.6	1000	1000
	366.23	0.938	0.945	        	        	366.52	1800	32.3	1000	1000
	366.82	0.899	0.945	        	        	367.14	1800	35.3	1000	1010
	367.43	0.953	0.945	        	        	367.74	1840	53.4	1460	1000
	368.03	0.953	0.969	        	        	368.33	2000	91	1660	1140
	368.64	0.953	0.977	        	        	368.94	2240	112	1740	1390
	369.25	0.922	0.984	        	        	369.55	2640	140.6	1740	1700
	369.85	0.969	0.984	        	        	370.14	2960	161.7	1590	1880
	370.45	0.992	0.984	        	        	370.77	3240	172.9	1580	2050
	371.06	0.961	0.984	        	        	371.36	3280	174.4	1370	2080
	371.67	0.875	0.984	        	        	371.95	3480	37.6	1000	1430
	372.26	0.774	0.945	        	        	372.56	3480	15	1000	1100
3	372.87	0.891	0.945	        	        	373.16	3440	14.3	1000	1040
	373.47	1.991	1.047	        	        	373.76	2680	12.8	1000	1020
	374.06	1.991	1.047	        	        	374.37	1840	14.3	1000	1020
	374.67	1.991	1	        	        	374.97	1120	25.6	1000	1010
	375.27	1.991	1	        	        	375.57	1040	26.3	1000	1000
	375.88	1.257	1	        	        	376.18	920	25.6	1000	1000
	376.48	1.078	1	        	        	376.78	880	30.8	1000	1000
	377.09	0.969	1	        	        	377.4	1480	32.3	1000	1000
	377.71	0.984	1	        	        	378	2280	33.1	1000	1010
	378.3	0.969	1	        	        	378.6	2120	25.6	1000	1020
	378.89	1.023	1	        	        	379.21	2160	17.3	1000	1010
	379.5	1	1	        	        	379.8	2120	15.8	1000	1010
	380.11	1	0.961	        	        	380.4	2040	15.8	1000	1000
	380.71	0.977	1	        	        	381.02	1960	15	1000	1000
	381.32	1.569	1	        	        	381.61	1880	15.8	1000	1000
	381.92	1.094	0.961	        	        	382.21	1840	22.6	1000	1000
	382.52	1.008	1	        	        	382.83	1840	29.3	1000	1000
	383.13	0.977	1	        	        	383.43	1840	35.3	1000	1000
	383.74	0.953	1	        	        	384.02	1920	48.9	1000	1020
	384.33	0.969	1	        	        	384.63	2000	48.9	1000	1040
Code:
	94.46	0.992	1	        	        	94.75	800	36.8	1250	990
	95.06	0.914	1	        	        	95.35	1480	60.9	1000	1010
	95.66	0.914	1	        	        	95.97	1520	51.1	1000	1030
	96.27	1.062	1	        	        	96.57	1360	54.1	1000	1040
	96.86	0.953	1	        	        	97.17	1480	63.9	1000	1050
	97.46	1.008	1	        	        	97.77	1440	63.9	1010	1060
	98.08	1.016	1	        	        	98.37	1840	77.4	1150	1090
	98.68	0.992	1	        	        	98.98	2360	83.5	1270	1200
	99.28	0.969	1	        	        	99.59	2920	72.9	1000	1390
	99.89	0.969	1	        	        	100.19	2360	18	1000	1110
	100.48	0.86	1	        	        	100.79	1880	53.4	1000	1040
	101.11	0.945	1	        	        	101.39	2080	72.2	1070	1100
	101.69	0.961	1	        	        	101.99	2240	75.9	1120	1190
	102.3	0.984	1	        	        	102.61	2480	75.9	1170	1250
	102.9	1.016	1	        	        	103.21	2680	95.5	1440	1360
	103.51	0.984	1	        	        	103.81	3040	134.6	1600	1630
	104.1	0.922	1	        	        	104.41	3360	160.9	1570	1850
	104.72	0.984	1	        	        	105.02	3520	145.1	1480	1770
	105.31	0.906	1	        	        	105.62	3640	76.7	1000	1730
	105.91	0.86	1	        	        	106.23	3120	15	1000	1130
	106.53	0.899	1	        	        	106.83	2640	80.5	1420	1140
1	107.14	0.922	1	        	        	107.43	2800	97	1370	1430
	107.73	0.93	1	        	        	108.04	2960	92.5	1360	1580
	108.34	1.023	1	        	        	108.64	3120	67.7	1000	1460
	108.94	1.047	1	        	        	109.24	2600	16.5	1000	1120
	109.53	0.899	1	        	        	109.85	2040	16.5	1000	1040
	110.14	1.047	1	        	        	110.44	2000	75.2	1080	1070
	110.75	0.953	1	        	        	111.05	2040	72.9	1010	1180
	111.35	0.977	1	        	        	111.66	2080	67.7	1000	1200
	111.95	0.992	1	        	        	112.26	2160	68.4	1000	1210
	112.56	1	1	        	        	112.86	2200	66.9	1000	1210
	113.17	1	1	        	        	113.46	2240	66.9	1000	1210
	113.77	0.984	1	        	        	114.07	2280	60.2	1000	1210
	114.37	0.992	1	        	        	114.68	2320	57.1	1000	1180
	114.98	1.008	1	        	        	115.28	2360	57.9	1000	1170
	115.58	1.008	1	        	        	115.88	2400	57.9	1000	1170
	116.18	0.992	1	        	        	116.49	2400	53.4	1000	1170
	116.79	0.992	1	        	        	117.09	2440	53.4	1000	1150
	117.39	1.016	1	        	        	117.68	2440	47.4	1000	1120
	117.99	1.008	1	        	        	118.3	2440	42.1	1000	1080
	118.6	0.984	1	        	        	118.9	2480	39.8	1000	1060
Code:
	333.73	0.969	0.953	        	        	334.04	1920	17.3	1000	1000
	334.34	0.93	1	        	        	334.65	1960	25.6	1000	1000
	334.95	0.992	1	        	        	335.25	1920	27.1	1000	1000
	335.54	0.992	1	        	        	335.86	1920	25.6	1000	1000
	336.16	0.992	1	        	        	336.46	1920	24.8	1000	1000
	336.76	0.992	1	        	        	337.06	1920	24.1	1000	1000
	337.37	1	1	        	        	337.66	1920	36.1	1330	990
	337.97	0.891	1	        	        	338.27	2160	90.2	2060	1130
	338.56	0.938	1	        	        	338.86	2480	113.5	2200	1400
	339.18	0.938	1	        	        	339.48	2920	144.4	2250	1730
	339.78	0.977	1	        	        	340.08	3400	157.9	2220	1800
	340.38	0.992	1	        	        	340.69	3840	168.4	2020	1990
	340.99	1.023	1	        	        	341.29	4160	183.5	1640	2180
	341.59	0.953	1	        	        	341.89	4280	161.7	1310	2320
	342.19	0.852	1	        	        	342.5	4120	14.3	1000	1230
	342.8	0.906	0.969	        	        	343.1	3200	15	1000	1080
	343.4	1.008	1	        	        	343.8	2680	13.5	1000	1030
2	344.1	1.991	1.047	        	        	344.4	2560	13.5	1000	1020
	344.7	1.991	1.047	        	        	345	2120	14.3	1000	1020
	345.3	1.991	1	        	        	345.61	1920	19.5	1000	1010
	345.9	1.195	1	        	        	346.21	2400	15.8	1000	1010
	346.51	1.008	0.961	        	        	346.82	2360	15.8	1000	1000
	347.11	1.211	1.047	        	        	347.43	2320	12.8	1000	1010
	347.71	1.991	1.047	        	        	348.03	2280	12.8	1000	1010
	348.33	1.991	1.047	        	        	348.62	2200	13.5	1000	1010
	348.92	1.991	1.047	        	        	349.23	2160	12.8	1000	1010
	349.54	1.991	0.945	        	        	349.84	2120	15	1000	1000
	350.13	1.078	0.945	        	        	350.44	2080	15.8	1000	1000
	350.74	0.969	0.945	        	        	351.05	2080	18.8	1000	1000
	351.35	0.906	0.945	        	        	351.65	2040	19.5	1000	1000
	351.95	0.922	0.945	        	        	352.25	2040	20.3	1000	1000
	352.54	0.953	0.945	        	        	352.86	2040	26.3	1000	1000
	353.16	0.938	0.945	        	        	353.47	2080	27.1	1000	1000
	353.75	0.938	0.945	        	        	354.06	2080	27.1	1000	1010
	354.36	0.945	0.945	        	        	354.67	2080	26.3	1000	1010
	354.97	0.945	0.945	        	        	355.26	2080	25.6	1000	1010
	355.58	0.953	0.945	        	        	355.87	2080	24.8	1000	1010
	356.16	0.953	0.945	        	        	356.48	2120	20.3	1000	1010
	356.78	0.945	0.945	        	        	357.07	2080	20.3	1000	1000
	357.38	0.961	0.945	        	        	357.68	2080	19.5	1000	1000
	357.97	0.953	0.945	        	        	358.29	2080	19.5	1000	1000
	358.59	0.945	0.945	        	        	358.88	2080	20.3	1000	1000
	359.19	0.945	0.945	        	        	359.48	2080	20.3	1000	1000
Also changed the fuel relay yesterday to see if this helped with anything but it hasn't made any noticeable difference.
However I now get the intermittent fault code "fuel pump relay - open circuit"
Code pops back up the second I clear it with the engine running.
the continuous dumping is mainly when cold.
With the missfires I couldn't tell you as I only drive it at high revs when its warmed up
Did you ever find out what the problem was with yours?
its fuel pressure related, thats why its running rich an lean throught rev range.
the fuel pump relay code is a clue i bet the in the lift pump is blocked or dying so drawing loads of current
Nope I never got that far dude...We seemed to think it was a Sticking lifter on cyl 4 as soon as it was warm/hot it was perfect...Even when cold after a few minutes of driving it would soon go away Oddly...
Have u checked the Injectors?
hrm, fuel pump relay is an odd one as it only brought up the code after I fitted a new one (although its a gsf one)
I'll put the old one back in on the weekend and see how it goes.
Injectors were checked, bill swapped them for a known good set
Is there anyway I can confirm its the fuel pump? Don't suppose vag-com can log fuel pressures?
I dont think so but does pump make wining noise
The lamda switching is correct but seems to err on rich side most of time
not that I've noticed no
I was thinking is it possible the lambda sensor could be giving false readings? The logs look like the ecu is controlling the fuelling ok but what if its running on the lean side but lambda is reporting everything to be normal?
misfire is usually when the fuel is being ignited at wrong time, thus timing out.
is yours is a vvt engine?
im wondering if its stuck on full advance which is why it drives ok at high revs, this would explain the misfires at low revs as timings out
sorry thread is a bit confusing.
Continuous dumping is at low revs (with nothing showing on the missfire counter)
missfires are at high revs above 5k
I'm getting to the point where I'm thinking replace fuel pump and replace vvt, after that there isnt much left apart from little things.s
pump pressure must be able to be checked shrader valve on fuel rail is for this.
Might be worth getting oil pressure checked too
O ****,!,
I forgot to mention my mate many moons ago with a Ibiza cupra used to get a miss fire under wot or high rpm after many months of spending it was the fuel pump...
Il try and find his thread for you to see if it could be that his did the same as urs though from memory
hrm, I tempted to bite the bullet with the fuel pump, its 7 year old car and it worth eliminating plus it'll be a bonus if I do more with the car in the future
Bill, in terms on the cylinder head what parts were swapped from my old head? was it just the cams and the VVT/tensioner?
everything
vvt imho next item.... fuel pressure was ok during the misfires when i was logging it
I have a spare 032A ecu now, same as yours is i think... if i do a defeat on it, it can be used to diagnose if ecu itself is playing up perhaps
