hi, got into the lcr today and pulled away after about 30 seconds the handbrake light started flashing with 3 loud beeps like the beep you get when low on petrol ect, after 3 beeps it flashes for abit longer then goes out untill another few seconds has passed then it does it again it will keep doing this untill i stop and turn of the ignition, if you start it with the handbrake on everything is fine its when its released and you pull away it will bring the light on, now i can only guess this is a faulty handbrake switch but what do you think it could be?
if it is the switch where is it located?
also ive had the engine light come on a couple of times recently, i dont know why but everytime it has come on the car has been a poig to drive like a second of hesitation on the throttle, easilly stall it if i pull away when its playing up, ive changed all the coil packs as i thought it was that because 1 did fail on me so i changed the lot, but it didnt make a difference, do you think it could be the maf?
thanks for any help
Dave
thanks for any help
Dave
on Sunday im meant to be going somewhere (a 45 min drive away apparently) with her
