LCR Rear Suspension Creaking Noise
nutter_engineer
175
Recently I;ve noticed theres a creaking noise coming from the rear of my LCR. You can just hear it when you are slowly pulling away from a stand still and also when I get out of the car. You can hear it quite loud when you push the car from side to side. Only thing is, its not always there. Sometimes it goes away, but when you hear it, its quite noticeable. The car is a 2005 done 45K and I only got it from SEAT 4 months ago. Is it worth getting them to check it and is it likely its going to be something covered by the warranty?
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
is your car a miracle self healer willie, the noises in yours seem to just go matey.... maybe i should asopt the ignore it tactic
Ronin225
4,647
22
Worcester
Only creaking i get from my LCR is due to the addition of a 28mm ARB or if the handbrake is not on or off fully
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Was thinking about this last night.
When I removed my OEM rear springs there was a lead/alloy spring seat that was worn away to nothing.
Wonder if its the rear springs scraping on the spring seats.
Perhaps try to remove these springs and coat the seat in a heavy duty grease
nutter_engineer
175
I've left this for the past week but the noise is still there. Infact I think its there all the time now. Think I'm going to get it checked. If I put it into SEAT to look at it, do they charge you to look at the car? I was looking through the used car warranty policy and it says if they find a fault thats not covered by warranty then you have to pay the cost of time to dismantle/inspect your car. Whats people experience of this? Dont want to put the car in, then find out its either no problem or not covered so they charge me for checking it out.
S444RAA
My car creaks with a 'full load' but it's totally standard and ever got it looked at as had services, mots etc and nothings ever been picked up,.
nutter_engineer
175
Ok rules out that theory then....
Brakes sticking on slighty? They will creak when you pull away if the pistons arent fully retracting when you release the handbrake or footbrake....
But that still doesnt explain it when you rock the side from the side at a standstill and you definately hear loud creaking coming from the rear suspension. Think i better still get it checked out, but was wondering if people had any experiences of the used car warranty from SEAT??
Jun 10, 2009
70
Newbury
did you ever get this sorted, mines doing it now and its driving me insane, i think its the suspension. But i want to confirm it before i buy a a new suspension set up for nothing. Its going in on monday!
nutter_engineer
175
well it was checked by the dealer and they said they couldnt find anything wrong and put it down to most likely the brakes binding a little. They also said my rear seats werent adjusted properly and rattling a little so that could of been the noise. Since I got it checked a checked a couple of months back I've not noticed the noise.
Aug 1, 2009
511
Hemel Hempstead
I have this one my LCR too. I only notice a noise from the rear when I get out of the car, ie. leaning out to th side. I did wonder if something needed doing, so maybe I might have a word with the local dealer or something. Again, mine is stock (apart from an induction kit) from the guy I bought it from. Just looks silly when you get out of your lovely, shiny, aggressive looking car, some people are about, and it sounds like a 10 year old Nova :)
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
When I removed my oem suspension there was an alloy plate (well corroded) that was below my rear springs. Perhaps this is an 'anti creak' device that wear out.
According to vag cat its a 'ring' lol
Part number 1J052109
