LCR start up
Goose1
LCR '52' plate will not start...... The battery in the fob and car are absolutely fine the problem I'm having is after getting into the car putting the key in the ignition turning it two clicks so all the lights display as normal then the fuel pumps primes but then I turn it once more to engage the starter but nothing happens!? As I said the batteries are fine and the immobilizer is fine. And the car starts when bump started. Has anyone had similar problems if so what was it and how was it fixed... (starter motor has also been checked off the car and operates fine)
Goose1
Thanks for all your replies.... I've heard through others aswell that the S3 had similar problems with wiring corroding so just gotta track all the wiring to find the point...........
