right finsihed my gardening now so going to shower off and hav ea play. Just to clarify i need to plug the cable into the car first wait a short time then plug into the computer and off i go??
right finsihed my gardening now so going to shower off and hav ea play. Just to clarify i need to plug the cable into the car first wait a short time then plug into the computer and off i go??![]()
****!!! I cant get mine to work I plugged it into the car, turned on the ignition, left it a short while then plugged it into my laptop. Loaded up vag com, did the test and nothing!!!!! Just get an error message. I dont know if it is because i am using a mac and have to use windows in a virtual machine so i may try it later if i can find a laptop.
I can hear something rattling around too inside the cable, only sounds small shall i open it to investigate?!?!?
window laptop = working!!!!
Have managed to have a good play around but couldnt change anything as i didnt have the internet on to look at dan gb's guide!!
Did a fault test and it has showed up that i have a fault with my 3rd cylinder.. cant wait to go to the garage next and i can produce a list of things that are wrong as apposed to the garage just deleting the faults and not doing anything!!!
use version 704... i'll pm you the link to download it. It's a RAR file so you'll need winzip or similar to extract. Also It's a torrent so you'll need a torrent downloader. PM sent
