I have the torrent download of Vag-Com 704 and when I reboot my computer I get a message to download the latest version. Anyone done this? will it cause me problems?
If you download the update it will kill your lead.
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
No problem, I found out the hard way, but I did manage to re flash it.
Plus from release 9.## upwards you need a differant lead.
£20 cable is that it? How complicated is this? I am a software developer...
Wouldn't mind tinkering and I need to read a DPF light fault also.
Just had another go and it seems to be working. Did a fresh install of 805.0 and reprogrammed the cable with the net off. Still come up with need license but didnt block the cable. Then tried unplugging the cable from the car and laptop. Plugged the cable into the car first then turned ignition on, then plugged into usb on the laptop and it all works great. Cheers for the help.
