Not really
Plates available to see on the street anyhoo so no biggy really
anyway.....
ABS woes continue.
So I replaced the ABS sensor, then I had the challenge of doing a system test. This is where the ABS light stays on and it wants you to do a system
This involves pressing the brake pedal, then the TCS light flashes commencing the test, then driving slowly at around 15mph turning left or right until the ABS light goes off.
Took several attempts but got it to do the test eventually.
Then I took it for a spin, and STILL the same issue with the ABS kicking in
It's going off to AMD on Monday, to determine if it's a hardware issue or wiring fault.
upon inspection the other day the ABS wiring was damaged and taped up, this could be providing an intermittent signal (as it did show a V64 hydraulic pump issue intermittent signal) which could be setting it off, so the signal is going to be measured when driving
to top it off, its now running at 0.8 bar boost as the N75 is broken. New one arrived today so going to test that out at the weekend also.
all last minute work, before or IF it makes it for its remap
