well it's good news and bad news
Good news is, that it has passed it's MOT and ready for show season, or at least it was...
bad news is that I STILL have a wheel wobble on the front nearside, when hitting corners at pace.
If I go slowly round a corner it's fine, soon as I do it with pace, TCS kicks in and something is majorly up with it. Now track rod ends, wheel bearings, bushes, etc have all been replaced.
There was a fault with the captive nut, where buy it simply wasn't tightening properly, causing the arm to shift and move about.
I have replaced the subframe, thinking this was it the captive nut, then when on the way to the MOT centre yesterday, hitting a long sweeping bend, the TCS and wheel wobble kicked in again
Jacked it up and checked over all the bolts in the subframe and all tight, no movement what so ever.
Also tried to shake the wheel hard for any movement from left to right, and still nothing.
The one thing I haven't tested is trying a corner with the TCS OFF...and see what happens, faulty ABS sensor maybe or something wrong with TCS.
Last thing I can try is getting the tracking done as its maybe the wheel badly catching, as this has not been done since the subframe was fitted
Other than that, I am really out of things to test, because I have pretty much covered every component which connects the wheel to the shaft
