I will just leave this here...
went down to Portsmouth today to pick up the replacement subframe, was in bloody good nick as well, rushed back.
car jacked up and ready to go
[/URL]
Subframe was changed in an hour thanks to the help of Nick, but while changing it over we noticed the dog bone mount was absolutely shagged....literally no rubber left in the mount at all
[/URL]
now going to order a polyflex replacement one
got the dogbone mount done today, as it was absolutely fecked
Old rubber from the mount, absolutely soft as butter....an uprated mount from a supplier I won't mention]
[/URL]
Old bush insert cut off, but had to drill a 15mm hole....and drill bits come in 14mm or 16mm....so out with the 14mm drill and widened the hole until the small insert came out
[/URL]
insert out
[/URL]
Bush was then pressed in. This was a struggle, but managed to do it with a clamp I had. Took a few goes as it was only a small clamp and it kept sliding off the bush, but got there in the end
[/URL]
Put the whole dog mount together. Next challenge was to press the two main bushes enough for the bolt to grip through the center of them onto the connecting nut, but got there in the end
[/URL]
Fitted the dogbone mount tonight, hardly any engine movement now, and it's very stiff
[/URL]
Then started with fitting the supersize TIP.
Comparison (this is a custom made version as I run a K03 Hybrid, so it is a K03 fitment on the turbo end, but an 80mm MAF fitment the other end, as I run an LCR MAF)
[/URL]
Fitted...excuse the absolute mess and wiring everywhere as I am in the middle of relocating the battery as well which is to be tidied up
[/URL]
small bits of progress tonight
9.5mm bung's for the supersize TIP
[/URL]
Started making the heatshield template tonight. Cut and ready, bit rough around the edges and a few bits to tidy up but on the whole it's sorted
Looks like it sits very high, but that's because there is a bolt on the chassis so it's not sitting flush yet, and the bolt needs cutting off. It will sit lower once done.
[/URL]
Shielding is going to be made from 1.5mm mild steel sheet, sprayed black, then wrapped in reflective heat material
Ordered a few other bits as well arriving this week, more updates to come shortly ;)
Few things arrived today
Methanol intake pipe, thanks to Bill Brockbank at www.badger5.co.uk
[/URL]
6 speed quick shift as well.
[/URL]
Just ordering 1.5mm mild steel now for the heatshield and magmashield tape for the heat shielding
still sat on the driveway going nowhere...
Since stripping the car, the buttons for the TCS and fuel cap are hanging loose in the car, so I have started to make the mount. The VAG com port is also going to be mounted into this.
cut (maybe a bit too tall at the moment, but this is to be adjusted) and also small pieces to brace the sides of the mount
This is how its going to look. It will sit lower than this as it is resting on the two bolts which is what it's going to be bolted onto. Will spray it black also to tidy it up
Battery relocation done, but the boot is too thin to mount the negative wire too, which is causing a weak signal, so I need to get a longer piece of cable and mount it to the seat belt point
Final filter relocation bits arrived
Started on my heat shield properly, cutting it etc
From this
[/URL]
To this
[/URL]
fits perfectly, needs trimming more, and the holt cut out for the filter then its almost done
Did some more work on the car tonight, only had an hour or so though
Battery tray
two bolts in the way, out comes the angle grinder..... (earth for cable is going onto the engine mount where the hard pipe is)
quick clean
The issue with catch can as you can see is its a complete mess and in the way of the TIP, and the pipework is also in the way of the DV.
This needs to be relocated. I have taken it off its mount
Mock up of how it will look, and the catch can which is going to be mounted to the side of the heat shield. Other pipes need trimming down of course.
Got the day off on Thursday and Friday so I aim to finally complete it all then :)
Also just ordered a 5m roll of magmashield, to wrap the heat shield and to wrap the pipe going onto the filter (will also be sprayed satin black)
Example picture:
[/URL]
are you bolting the maf to the shield and extending the wires or adding silicone between the two?
no not bolting it (couple of the bolt holes are snapped anyway), will just be secured with jubilee clips and fitted between the silicone...its a tight fit getting it all in and onto the TIP
Magmashield turned up today :D
got tomorrow and Friday off, so I can crack on with it.
Monday a mate is coming over to mine on Monday, to finally sort out the battery, so I can get her started again and back on the road
So finally finished off my custom heat shield yesterday, really pleased with how it has turned out!
Hole cut out and filter mounted
Trial fit
7
rubber mount
Sprayed satin black
and here it is finished, wrapped in magmashield as well :D
Looks good. I'll be interested to see what you make of the new brake pads.
getting them fitted on Monday mate so will be a little while till I can test them in full anger but will let you know what they are like.
DS2500's are good...but they do suffer from fade when pushed quite badly I found
The heat shield looks good mate
Thanks mate...alot of time spent making this. I wouldn't do it again, it wasnt difficult....just fiddly
Finally got the car up and running today with help of Nick.
It was such a stupid problem as well.
when I originally took apart the battery fuse box to fit a new cable, I only did up four of the nuts...leaving the other four loose
We scratched our heads for a few hours this morning. We went and bought a volt meter tester in the end, 4 of the nuts were good and showing good current, but when testing other areas of the fuse box, the signal was very weak.
We only figured this out because when applying pressure from the volt tester, we faintly heard a few sparks....then we realised the four nuts were loose....
tightened these up and hey presto.
SO frustrating because everything I had done with the battery relocation was right, and it was all undone from 4 nuts loose on the fuse lid![:@][:@][:@]:censored::censored:
I can't believe it was something so stupid!
I then went for a test drive...almost straight away the car died on me and the EPC light came on and the car was struggling to run.....something had popped off
found that the charge pipe to turbo had not been tightened.[:@]
Limped home, tightened it and all good :clap:
