New bonnet catch and I was missing a stud on the far right of the inlet manifold, so bought a set of these
Forgot I had this, carbon fiber coil pack cover. Gave it a quick clean and its come up really well from sitting in the garage for months!
ordered some blue anodised bolts for the carbon cover, coil packs, braided hoses and hose coupler, so a few bits going on next week
So got a few bits done on the car tonight
Phenolic gasket reinstalled. Now I didn't intend to put this back on, but I knew the far left stuf was missing. There is two studs on the left and right that hold the manifold on and the rest are bolts. So to do the job properly I had to remove the whole inlet manifold to get this stud in. What a fecking pain in the ass.
While it was off I couldn't reinstall the OEM gasket as it was foobarred and bent taking it off, so I thought I would reinstall the phenolic gasket again. WOW, what a ball ache. Because the gasket is so thick you literally have less than 1mm of thread left on the bolts to grip and screw in, which simply wasn't happening. For some reason I had a pack of bran new longer bolts. Where they came from I have no idea, but they were a god send
Gasket
Two types of OEM bolts. The longer bolt with 2mm more on the thread really is the difference with the bolts tightening and just turning
Part number for anyone interested
I then replaced the bonnet catch. For the first time in 6 months the bonnet now closes nicely
I then replaced the grill as the badget was fecked and snapped with a badgeless grill
I bought some braided hosing to replace the old hosing, as well as two hose couples too keep them tidy. Here is the cut and ready
I had some hose end tidiers, but on the old braided hoses they are much thinner and the new ones are much thicker, so these do not fit and I will have to order some new ones
I then got on with some more resistor crimping and tidying away the old cabling
Installed the new fuel lines
Thought I would opt for a bit of colour and went for the green hose finishers
Just waiting on some piping from Forge, 90 degree pipe joiners so I can relocate the DV and thats pretty much it until next Friday....
so went out for a test drive and it was blody lucky I did really
just turning into my estate and I literally heard a "ping", then the car would not move at all. I first thought the brakes had jammed on.
Rung the AA, and I had already taken the wheel off etc, so a nice easy job for him, tools out and ready also for him
He diagnosed the issue quickly and the track rod had snapped clean from the ball joint. The car would not move because one wheel was going in one direction and the other wheel was going in a different direction. With a bit of muscle, the AA guy manually turning the wheel as I drove the car slowly we got her parked up
So I drove over to Nicks to pickup a set of lower arms and wheel hubs, top man! saves the car sitting on axle stands for months on end, and means its easier to do a straight swap when the time comes
How I got them:
Spent an hour cleaning them tonight
de-greasing
First scrub down with a wire brush and picking the old paint off with a screw driver, a bit to go yet
These are going to need quite a bit of work to get like new again
Thanks to a few members off Edition today, they pointed out a 30% sale on euro car parts, so ordered two new lower ball joints and two new wheel bearings
Next up is to scrape all the sound deadening out of the leon, take the roof lining out and as much weight as possible....potentially the air con as well as that weighs a ton
Bought some of this today....not cheap but will make it easier and get the job done
and here's a picture of her next to my mates R5 before she was SORN
Been trying out the rust stuff today, it's actually really good, and has really stripped the rust off with very little work
still some discoloration, but it has stripped the rust and some paint right back. I am going to leave it on over night, then clean it off tomorrow. Pretty much done and ready for painting then
This was one of the worst arms. A lot of rust has been stripped but still a way to go yet
few bits arrived
ordered some snow foam as well to clean the rear arches as I will be sealing these, shortly and ordered some butyl as well to sort out the leaky doors
Bought these from AKS Tuning as well, OEM+ coolant and washer caps in black, look awesome. One problem with spraying the washer cap is the paint cracks when you bend the fixing point back onto the bottle. This doesn't happen with this washer caps as the actual plastic is black
Coolant
Washer
Snow foam turned up also, so I can prep the arches and sills and get sealing these before the cold properly sets in
Had a fairly productive evening tonight
Gave the arms a final coat of paint tonight, all done. Just need to drill out the bushes ready for the new polybush ones
Then I got onto the black sound deadening, was quite therapeutic doing this actually
To the side of the footwell
Then the spare wheel well
A good 5kg of this stuff already, and got the whole of the footwells to go which is very thick, so a good 15-20kg I reckon of weight to come
Got a shot of the engine bay, very dirty and bogging looking, nothing pretty about it
cracked on with working on the car.....now with nights drawing in quicker, back to working in the dark
Sound deadening removed from under the rear seats
Removed the drivers seat, and cracked on with removing more sound deadening
First half gone
full bag already of sound deadening, good 10kg's already
Up in the air again
Spot the difference and what is missing....
Dirty arch
Cleaned guard
During clean
Spotted three spots of rust, so I am glad I started this job now
Lower arms all done
Arch now sealed and left to dry
Decided to start tidying the interior up, and get rid of the old glue left over from the sound deadening
Before
After
Rear patches tidied up
spare wheel well (still a bit to sort)
Made a brief start on the drivers side
Before
After
Roof lining, grab handles, interior lights and plastic side pillars removed
The car was absolutely full of water, I knew it had a leak but didn't realise it was this bad....and we have had some pretty torrential rain
Luckily I left some big cloths in there to soak up the water....I literally squeezed out two pints worth of water from them!
The water is pouring in from the pollen filter housing. I removed this last night, and the seals around the pollen filter were soaked. So I resealed these and I need to reseal the plastic cover against the windscreen, but ran out of sealant
Apologies for the poop quality
So the evening started off like this
Pollen housing...minging
Screwed seals around the pollen filter housing
Now resealed, so hopefully this will hold out for a while. Doing the rest of the sealant tonight
I finally got round to sealing the last wheel arch.
During cleaning
Sealed
Next up is finally crack on with reconditioning the hubs, removing all the old sealant glue, relocate the battery and start to design my custom housing to enclose the air filter.....
Got most of the old glue off from the sound deadening
Pulled off the passenger cover tonight...trying to find the source of the leak...and losing some more weight from the car
Before
After
Before
After
Going to sand the paint down, fix the snapped stud in preparation for carbon dipping
Wheel arch refitted for the last arch which was sealed
Finally got round to adding the last resistor to the removed SAI, so the error code stops coming up (Thanks to Mylo again for making this up for me)
tidied it away since the pic.
Sorry Bill....but I have rebuilt it since
Old Vs new pollen filter
Hopefully sealed the leak...but still don't think I have properly, as yet again the cloths on the passenger floor were absolutely soaking
3" Downpipe and decat off Nick
Silica Gel, to soak up the moisture, as still got a small leak, and water collects on the inside of the roof (no roof lining)...also with it sitting around so much it never gets warm to dry up the moisture, so this will have to do for the mean time
First set of polybushes arrived also
