with the engine going in so smoothly, there must be a part of you that thinks "**** this is going toooooo smooth" hahahaha.
Great to see the progress, slow progress is still progress. keep up the brilliant work.!
That was my exact thought yesterday as I was assembling the engine.
I'm sure I'll suffer down the road...
Happy you enjoy the progress!
It's coming along well mate. Cant wait to see it progress more
Thank you, stay tuned.
Lot's of smal bolts and bits to source now before I can get it started.
I guess another 4 weeks should give me the time needed before turning the key and cranking the engine.
This build is in something else amazing car and brilliant read and this thing is going to be mental
Sent from my D6603 using Tapatalk
Angle drive
I've sourced an 02Q angle drive for the future AWD conversion to come in the next phase of the project.
Just need to fill it up with oil and mount it, the driveline will be completed for this phase of the project.
y3mdzGWTj8H0HomU73DhOk8_V_7Gv3YOq1mt3Fb7Gkq9LQ9JrpXTkmv4Wem4FNdBB_Deno6foTAQm1hSERBNSOYTx62fO-5cGJqDCOKvJKXvtweHDiqzaIPS6CTcg04akZ_KDPiB95lsWvlefoSFvWGF8U8Q3CbFHP6KhQVlChbzMM
:wave:
Angle drive fitting
The angle drive installation might be an easy thing to perform but in my case it ended up being an adventure. A radial shaft sealing intended for the FWD application was preventing me from getting the angle drive to mount up.
At last I discovered the difference and got hold of the correct seal, 02Q409189 enables the 02Q FWD gearbox with a AWD differential to accept the angle drive.
Interesting how you sometimes get all wind up and miss out on minor details...
y3m1snhHBS90FT-ywnqFjz4qJvqLEcUbRo_zO2j_LevEZN-cF8HrFz3AJLIzsmL10oxJyp-hwDTS45MIkn5rrVVT6eYQewdr_2uBhrjOIaXL0ibs8ynoKZPH8-r9iHpWY2PaIGtsamgnXMaPjln2s2v4SyCicfI3Zw_OaZUdpNKJ1g
:wave:
TTRS Pump
Moving on with the build but slowly, always a gasket or screw missing that I have to order and wait for.
Dropped in the TTRS LPFP (Low pressure fuel pump) and fitted a plug to the secondary support pump output/input.
As you might know the fuel tank is split into two tanks on a AWD set up, in my case it's not and thereby the secondary support pump is not needed yet.
I suspect that I'll have issues with the fuel level readings due to difference of the fuel tank but not a crucial issue at this stage. Should be resolved further on when I go AWD, second phase of this build
y3mybcQoXaQ_nSCAebgU0fjoMdTwRp00JQiOD938aSdCVG2H3zOIpME-IRmxcS3keaR0F-DuamRsrqLGr8tzixrT6yWtrSJ0ljy7Eb1xZWUZN_N9OkW1nQ3quZNjBcW8oQ1xWYgSXxmE5wUqE6rFEJ2b1TNtYt38gp3pXQwYLYv1aA
:wave:
Downpipe
The build is moving on despite the lack of posts on here. I really believe I'm in the final stage of sourcing parts for the build...
One of those parts is the downpipe that I at last ordered this week after carefully investigating what the options are.
The kitt comes with a CAT and piping to connect the OEM exhaust fitted on a TTRS/RS3, I'll produce a custom mid-pipe in between to instead connect to my aftermarket 3" CAT back.
y3mexBIaGBZ0Aflf0140gGatno_SWNfa3M5tSms-1vWesLfX9YCn6BUuJDWX2qYw3Y58xA1sNmnovnJN5sTnlAFrTq1Qd_jiAmp_2U7jbJU1FFn4w1_l9FtQFesmnjf6belGbD4VW_nCBeitNqsrdeEvSuw9kc_tdJCgSHqnKlGPEU
y3mo3ucdLOm5l02a6NQU8jCR4bTwipwIi1a0G2tcgpkf0GwJlTUUOmCLFENJ7NjDuV5dZEDIa7csDXpJ_KEUuTk2_gBdGEgFjPYnFvDnZ-c0VSB0eLtjoAMt4mNkD3r9TCTsVkMbxmkzcUpHv0sDamsCevjd91TTuCxoHdbSzJsd1w
y3ms85Tw8ukXVb8jDo0YYV3zhamnmQnWKhb_NgzY4Q-z5iS8rU-_bwhUiS9eBg1Hjpe9LZ5LSxyYEHQAyiXDi_kqwk-BhNp28Cw1wdvrUw1x2vc4f-HIRArOIx6mSKIk_plyNf4K-89LemMjmUysTfece9VdPJqjckw4Y_uUODfk-k
My selection was not done due to a specific brand, it was all based on functionality. This APR 2.5T downpipe is casted and has a smooth and large reducing initial neck to allow the exhaust gases to expand and cool down.
This is really the only off the shelf downpipe on the market that according to me makes the transit in between the turbo exhaust side and the downpipe in a proper way, smooth downsize from 4.68" too 3".
Other downpipe options utilize a direct downsizing 3.5" connecting exhaust flange, this prevents the exhaust gases to exit in a optimal manner.
In the image below you can see one example of the (non casted) welded 2.5T downpipe option from the same supplier, have a look on the initial neck to see the direct obstacle the flange creates.
y3mAfuMTWQ8Zum4MiviGBp5agKslKWs4JCoD6bRzLcYTbPKc3tYwz1sauWnaHb72vdL8XPotlxDCYJhlJKOyl2kO5OIhwH60oggURfKEcME9VmmAUCr5y_s1Xv0zZTJkMagEecsmB4Oqk6AI0l8zlI2Lh48y57dSnoUgv5de-PBDMY
:wave:
Progress
At last the electical engine wiring, coolant piping, intake manifold and valve cover are all on. Lot's of time used to figure out where goes where but it's been a pleassure to slowly get it all together.
You know the feeling you get when you have 10 puzzle pieces left in a 1000 pieces large puzzle...
y3mrY1R-cFd9YzewAv3UphYT7hrSJgOdzLc31ANgAQPnptWY7g3wkJKdIMWHBEu9awxEtT8oqLJYG5yL9f8AZfe073gMeKcijNWkW70Svas3kXxlvjdgo-68amrSiW9CzECgrJOMVvpv_Zgm9bvafUCl0Twh93b0guOyEGVqrnT_Cc
Coolant radiator
Ensuring proper cooling with an Mishimoto coolant radiator, increased fluid capacity and optimal heat dissipation as it's larger than OEM.
The 2.5TFSI engines come with an additional smal sized coolant radiator mounted on the front right hand side.
I won't be running with the additional radiator, inteanding to make up for the difference with the Mishimoto coolant radiator.
I'm confident I won't see any issues as I'm not located in a too hot country, additonally I'll be running WMI and a separate oil cooler.
y3mq1NODkhFhajTLKo4X8-tf6Khvv6GhYO-fIxan8vB7xv1NHxW6gQJUc56LcSWyXoTSNS8xvCfFh3dOO7OArefXkpKqvkS0ppHMc2iNLCOQLoG7Gkk3ac1QrQJ7zCDvSFQ2Y_PTxck9QGHNUHNaBA_g6XyOQYk4TZ3C-aSe3A-Qhk
RFD and EVAP
I have this urge to delete features and physical parts that won't contribute to the power curve.
The runner flaps is such a feature, intended to lower emissions during cold engine start up. By deleting them the airflow is optimized as the physical restriction is removed. They are seated in the lower intake manifold as per the image.
The access points for the bolts holding them in place are covered by caps, they were tapped and plugged with angled screws to ensure they won't decide to drop into the engine.
There are air dividers in the cylinder head that in conjunction with this delete are removed, they are in my opinion the largest air flow restriction on the 2.5 TFSI engine.
y3mGcPa24Nmg82JBOarzwSxOUlvLSMa4O8VkYWUZ0hYNBdbyz2Vj9jJTeBiVT6IWSdwitGSqeK3UbXLGOPcidvYw_dBnCO1gV4AKKLzxIyXANYqMcPWhEC1zIbE4MrgQdrh0Cey3TVeDi31RK4pYXUQA9zodFfdPv-kvn2NjJfT9KY
y3mwgNuuuSRaYwddRhZGg4UV9_ZSOihMykDCqXr5Qqn03bN09dQyNhyRs0D3yh2NEhougP1kWzcigFyJ5pJP69bTYAWfkoVGkvp5i9d5jWCgUVfmN4MdjcaF9Oa7J1kYBLIBYFSFozFHCrSps6EMeuhn-xK1ut8myDo-dr3Le-vn7M
y3m5WVd_JFZr1mzdpoItUnxh2IP1vtDyg931cojECSxLH0zxY_Mnt04TEYSyCUKdw-1xMBMuaiiv9i9Asgm8cg3UoMbgkouFTu3tNtnRxMWPbi3J1XgU5G090COIluGjt5jTy2LPJRzlQmaGdEL-7Zf6Xjz0hVi4e6NYUWyrICaeOo
y3mfLE29-EwS2n7m1zcoJ-bgAPWH6hltyvpvQkd0Bw73z1ynk20a4P1lWZraIEsEnrtsODh43KVyCrm8Ams6y8zEgEUqceUeXoGvhP2VVFm4MoeWqEfGaOco0eBDsg6nQLnSPXHlrxB3ShBjMgoTbANHEGzdJi7XrqJ4OUq4NhQCA8
The charcoal canister is another of those features that had to go. It's a part of the EVAP system that ensures to burn any fumes from the fuel reservoir.
Some hoses, valves and the canister itself can be removed, saving on weight =)
y3mg9zaB0IWqvLDiuRzQ9btxrQih7dfdLXg8Yw06ZInOfZSHKjRMR8poL28gINmNtM2zY5afI3weF4UM3Gsy7lVPgeJF5mDescUtJwYuh8HxiEDoTfQBuYzwCXn9sq0QRV_zQ6tk76xEc3S7iDYHgg-6pMFcmVKr99X0qmHW67fibc
y3mEowN1ufmYDS7F6bwkbrNiVorcTdwegxNl521WF4Gs-X3h7Yc9dIBDKJvbpxlHeZxBN_GImBF0XU1QvV9FF5MNvM5cx26TELkxtHqNYIxZTVDSfG5hCmzia9p4RFFi2uRpcnn5qCS5sJAkTUcmWIlBrEWMjHIsVwFnUawVj2Gkh4
:wave:
Intercooler
There are many opinions about Intercoolers in general and it's a topic that always is debated about. There are some great intercoolers on the market for the 2.5TFSI but I simply can't justify the cost in relation to what they are capable of.
The cost of the universal intercooler is among the cheapest of the exclusive components I purchased for my build. I selected a universal (Welly cooler) 600x300x76 mm quality Bar-and-Plate Intercooler with staggered/offset fin type.
The design has a optimal cooling effectiveness and low pressure drop, see the attached picture from a known tuner of the design differences. This intercooler will outperform many plug and play designs or be on level with the best.
Being a universal intercooler it requires me to do some custom fitting and piping.
The OEM designed intercooler holds the coolant radiator and AC radiator in place, I'll have to design brackets for the coolant radiator as this Intercooler will not be in the same location as the OEM.
y3mPJbxjM1tgW9iFZCK-mzIXlq0dFtBo5pFkHA3sPZi6g-ikB13YNAWaOcTY7n58JJtpdubIXLAKxc1DHJCImgB8t_QAR3NwaNcMkPTZmaoEZvKNd2lUIDLogy63ZeqEZQI5fD54w8EAT8hjjrCaxrunf_CnnFi8UPw6XS04pGvCng
y3mDF-D3SO0U6IlErFcLItcxkzFZY51jTLmPL5WzsDjdPtWAYEHtiI9TTYmKgjI3qd9YwuQNhdmEj9027624GTXsVUiZdBKaQYAYUUoDfKtKYmQvMB0ITNVa1g57yuvkz-gsmJBDp6eLGSo-WMae8bvuJuLxoBQjIc82ri2YcoiN90
y3mVeTGDLWv1PpgHSp7w_1v6bJkAWMXyCzjBwWoYhtakthiptzJ4XrUIKNe8bdIqfd2kND-0uxJuDko5xu9Jv1kMqlEU4f48kEdWZomSRRRKyz_QgzR-R_F2Q5aUvzDum8QAmb1sLP96jvr_AfgQTd3E6EDM_bmdrkKCU3ozZfCdSc
Aligned all the coolers to see the overall pack, I like it.
This cooling pack should handle any heat I throw at it =).
y3mykjCLcOJFbafcZQVgGNto7dXbRi2p7Dz_g0ZLyQdjrM2RQJxwH67FojamYzagUTFJqh2dewSuFUSTcTrWCvKFSUCJwe33v3DnrVfMS8RBlZJ18i9dbf5oFSRYC2uNFMvA86-rosnJmqIIToMtpuv9mxUPfXit56AqL13GgkeoGI
y3mn1z7YBmjIfoK85Du2qpYWVppEdA_CG4ZvSsGJAlyXE7GLT9ADUXzkhYVzt6oOZEglLCWrKeRNPhNiMo6hGzb-PZiPlcoCMU4e-1aQpDqcuHYhrvj7JhiNyJg6F6NwLJl3tkm4NREsIrWKjC6My529R9H2OWhDx1NlwMubam9Mlk
:wave:
Progress
Moving ahead, some obstacles along the way but nothing to serious.
Fueling lines and all the major engine accessories are now connected.
The 034 Motorsport carbon intake and engine carbon where a nice final touch. Thist intake has proven to be a nice power gain, for further details have a read in the attached link.
http://forums.vwvortex.com/showthread.php?7229110-Introducing-the-034Motorsport-Carbon-Fiber-Audi-TTRS-2-5-TFSI-Cold-Air-Intake-System!&p=88113043&viewfull=1#post88113043
Some of you might wonder why I painted the valve cover in black as it's originally red. I don't fancy red as it commonly used by so many. I did paint the valve cover at first in yellow, matching my calipers, but was not happy with the outcome so painted it black.
I'll incorporate some yellow details in there later on but not my focus at the moment.
y3m1uTRGxZ4uuw9c2hMpVp6zKXrih5OIrzo4uLwWjfP9SvBvVy3_Y6j-vs3IU-JH0S2Hl4mQK3WIcidSPgOQlkD7HL1UP__XLOdvgDn0BeAp-x1c7XSXq-nlIvdtcJ6JBkPrAweMHouwDwUsK1TOYAYIUfnk4UCnpq9sSauHpxVJcw
y3mc3Mdw4y1Ici66l8FQf3SyVl3nVJN_MH89UV19Hy2YiNo52nWqKsv8Z5fILeDChDVgqM-uNdZ0dJfYNTskUnOYiOD5ntZ_XcP5rfoc5yzGRfP2_idsB_jovlEfwJDYTZz9pipKVQhZAlb60x76EnrSeL57C1fhtd-R1Um1rp2IhA
:wave:
Cheers mate. I wil crank the engine in the end of this month if no surprises along the way prevents me...
I like it in the black, very stealthy and OEM looking.
Looking forward to seeing this thing running
Thank you, also looking ahead seeing it run.
Here is an idea of how I'm considering to color things up a bit in the engine bay.
y3mt5p0oPuxV8oQlITM_2dfWwGo7S7YIZb8yJNCzAshAyGjoQ1bhPYvkTdwpw4YOSoD-nDwRZ9tlmlfIjmrWgp5gZk6LRrFj_SqSc1SwxuuRjU32iUDx0l4FUyMklQ285_QuJor8WYURuHy9575dybmX-XzbJCPyjQJ5Xqxk6alXfg
Leave it in this color.it matches with brakes :cool:
VAG Familia
2016 LEON FR 110kW
