Leon mk 2 1.6tdi limp mode
33754k
159
Manchester
Hi
Looking for advice on my car - it's in limp mode and has 2 orange lights on (coil flashing when running) and the engine management warning light is also on.
Have run a basic OBDII scan on the car - think it's the EGR (error codes at the end of the thread)
Just wondering what the options and cost are (Map out/ replace EGR)
046C
Raw code: 046C
ECU: Engine control unit
Status: Confirmed
OBDII: Exhaust gas recirculation (EGR) valve position sensor A - range/performance problem
============2==============
7462
Raw code: 001D26
ECU: Engine control unit[Archive (inactive)]
Status: Test failed since last DTC clear
============3==============
7563
Raw code: 001D8B
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
Seat: P046C00: EGR Sensor "A" Circuit Range/Performance
============4==============
7462
Raw code: 001D26
ECU: 01. Engine control unit[Archive (inactive)]
============5==============
7563
Raw code: 001D8B
============6==============
3789
Raw code: 0ECD
ECU: 09. Onboard supply control unit[Archive (inactive)]
Status: Validated and stored in non volatile memory
andylong
494
That's dpf regen fail by the lights and you had some previous exhaust issue in january
33754k
159
Manchester
Sorted now. EGR replaced. Totally clogged up with carbon. Also explains my previous thread - smelly pungent exhaust. £700 all up with seals.
