Leon MK1 1.9 TDI 66kw - Power loss
Filip
Hi everyone,
I'm new at this forum and I'm love with my recently bought Leon.
Seat Leon MK1 1.9 TDI 66kw manual transmission.
The vehicle doesn't go above 120km/h and 3000rpm.
I went to few repair services and they weren't able to resolve this issue.
I've replaced the MAF sensor, and there was small speed up but on the lower gears (better start).
I've connected to VAG-COM and these are the engine errors:
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
17945 - Fuel Shutoff Solenoid (N109): Malfunction
P1537 - 35-00 - -
The last repair service, after playing a little bit with connectors, disconnected the Coolant Temperature Sensor and clear the errors. After this, the vehicle was running great. I was able to feel it the turbo running on my engine. But the repair service wasn't able to fix the issue with the coolant sensor and left me only with finding the cause of power loss, not resolving the issue.
I've connected to VAG-COM again:
2 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
The previous error (for shutoff solenoid) was dismissed.
I've played few times with connecting and disconnecting the coolant sensor.
There were same results:
If the coolant sensor is attached, the car have power loss, and on starting the engine it's a little bit noisy (1 second) make some black smoke. It went to 1100 RPM and then back to 900 RPM.
If the coolant sensor is detached, the car is going great, no black smoke no noise on start.
The coolant sensor was replaced previously.
Any ideas of what can cause the issue?
masterfrodo
266
8
I changed my coolant sensor last year. Since then the temp gauge reads 1/4, and very occasionally will reach halfway. But, doing a temp check, it reaches normal temp and stays there, so not sure whether I have a faulty sensor, or something in the dash - or even if a dodgy thermostat would do this
Filip
I've replaced the coolant temp sensor with new - original one. I can see the temperature values on VAG-COM and the dash, they are nearly the same. Once the motor is warm-up, the temperature is before 90 on dash, and 90.9 on VAG-COM.
Any other parts that can cause this problem?
I'm not sure where the fuel solenoid is located?
Filip
But what about the power loss, any idea what can be the cause of that?
Only happen when coolant sensor is connected.
MAF Sensor replaced
EGR cleaned
Fuel filter replaced
Coolant sensor replaced
Is relay 109 anyhow connected and can be the issue?
Filip
I've written in the first post:
If coolant sensor is disconnected: (no power loss)
2 Faults Found:
If coolant sensor is connected: (power loss)
2 Faults Found:
P1537 - 35-00 - -
Filip
Possible Solutions
Check/Replace Fuel Shut-Off Valve (N109)
Do you know on which position this part is located (Fuel Shut-Off Valve)?
I can't really find it on google for Seat Leon.
Connorg115
397
66
United Kingdom
I’m not very familiar with Diesel engines sorry, however if you know your engine code that may help locating information as usually there are many cars with the same engine
